Dear GRASSlist,
I am working with raster data that was converted from a lat/long basis
to an x,y basis with the following formula:
X = INT(Rad * cos(LatR) * LongR) / Cell) -AdjustX
Y = INT(LatD / YBand) - AdjustY
where:
Rad = Earth's radius, 6366707.444 meters;
Cell = size of the grid cell: 1000 meters;
LatR = latitude of position in radians;
LongR = longitude of position in radians;
LatD = latitude of position in decimal degrees;
Yband = (180/(Radius * pi)) * CellSize;
AdjustX = 0.5 if latitude >0, -0.5 if latitude<0;
AdjustY = 0.5 if longitude >0, -0.5 if longitude<0;
(1) If I read the conversion correctly, X is the arc length along
lines of latitude from the prime meridian, and Y is the arc length
along lines of longitude from the equator. The resulting x,y basis
maps for North America are strongly skewed from southwest to northeast
(because the X arc distance along a line of latitude is shorter for
more northern latitudes, right?) Are there any thoughts from the
GRASSLIST on the consequences of this conversion?
(2) I have several GRASS vector maps now on a lat/long basis (from the
US census) that I would like to convert to the same x,y basis, i.e.,
take every lat/long point in the map and convert it using the above
formula. Is there a straightforward way to make this conversion in
GRASS? I have read the documentation for v.transform (and v.proj and
several other possibilities) but it seems more complicated than I need
because it will stretch, etc., to make the transformation line up. I
have an actual formula. Is there any way to convert every point on a
lat/long map to this x,y basis using the above formula?
I would like to try this conversion even if there are good GIS reasons
not to do it. Thank you very much.
Best,
Michael Ash
