[GRASSLIST:9143] problems with v.in.ogr
hello,
I'm a grass 6.0 newbie, and I am experiencing a few problems using it. The major one is importing data.
I tried to import some vector data in shape format. I was able to use them with other gis softwares (Arcview, Geomedia), so I guess there are no issues with the data themselves. Anyway, I used v.in.ogr to load a shp file, and here is the given output log:
v.in.ogr dsn=/home/marco/grassdata/data/Bacini/gaiana_UTM/BacIdrograficoDigitalizzato.shp output=gaiana_digit_3 min_area=0.0001 snap=-1 -o
Over-riding projection check.
Proceeding with import...
Layer: BacIdrograficoDigitalizzato
ERROR 3: Error in fseek() or fread() reading object from .shp file.
1 feature without geometry.
Building topology ...
Registering lines:
0 primitives registered Building areas:
0 areas built 0 isles built
Attaching islands:
Attaching centroids: Topology was built.
Number of nodes : 0
Number of primitives: 0
Number of points : 0
Number of lines : 0
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
I tried to display the imported file, but there was nothing on the display, obviously. I followed exactly the same way to import another shp file; there were still some warnings, but the file was imported, and I succeded in displaying it.
Has anyone suggestions?!?
Thank you in advance!
Marco
