[GRASSLIST:9181] xy location to projected location
in GRASS6.1
a vector file created in XY location cannot be RE-projected to a PROJECTED LOCATION
but however
  1. a raster can be georeferrenced to any projected location.
So, If by oversight, you painstakingly vectorise a scanned raster in XY, and then project it to a location, you will discover the mistake, too late… The resultant vector cannot be projected.
Instead
Project a raster image into lat long/ any other projection, and then do all the vector conversion, you are in the right track.
  1. If the deductions above are correct… Will the developers look into, and create a method where XY vectors can be projected.
ThanQ in anticipation!
Ravi Kumar
Yahoo! FareChase - Search multiple travel sites in one click.
Ravi,
Does v.transform help?
Maciek
On pon, 2005-11-21 at 23:24 -0800, RAVI KUMAR wrote:
in GRASS6.1
PROJECTED LOCATION
but however
too late.. The resultant vector cannot be projected.
Instead
2. If the deductions above are correct.. Will the developers look
Ravi Kumar
W polskim Internecie s± setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.epf.pl/
