to change the permit on the mapsets for the utents of the machine , may
I do does edit g.access.
thanks, Dina
thanks, Dina
may I do does edit g.access.
Others on the same machine will be allowed read access if the UNIX file
permissions are ok and they have not been specifically denied access
with g.access. Only the owner of the mapset can have write access to it,
even if the UNIX file permissions say that others may write to it.
see the g.access help page. see also g.mapsets.
Hamish
only a simple question about g.access or similar.
there is a command that permits the write access on the mapsets by the group
users or only the owner of the mapset can have write access to it?
thanks
Leonardo
> may I do does edit g.access.Others on the same machine will be allowed read access if the UNIX file
even if the UNIX file permissions say that others may write to it.see the g.access help page. see also g.mapsets.
Hamish
