Jason, the method I generally use is similar to yours with some slight changes. I am pretty happy with my results, but each person has their own tastes naturally.
Using r.shaded.relief, set your altitude to a higher angle, I typically use 60.
Your color map is important. I use the following color map for maps with topography and bathymetry.
8200 255 255 255
7000 255 252 225
5000 252 245 193
4000 252 237 147
3250 250 231 105
2000 177 157 72
230 70 120 50
0 0 82 30
-1 255 255 255
-511 211 227 237
-915 152 218 235
-1519 127 255 255
-2165 204 255 255
-2722 224 251 255
-4200 33 163 255
-5800 38 57 224
-6500 148 33 255
-10799 0 0 0
You can set this (or another color scheme) to your map by first copying and pasting this table into a file (make sure to preserve UNIX carriage returns). Then use
cat your_file | r.colors color=rules map=DEM
then use d.his h_map=DEM i_map=DEM.shade
g'luck
-Ian
On Nov 22, 2005, at 1:59 PM, Jason Horn wrote:
I'm wondering if anyone out there has had experience creating
attractive color shaded relief images from DEMs. The basic procedure I
have used is as follows:
1) r.shaded.relief DEM azimuth=270 altitude=30
2) d.his h_map=DEM_shadei_map=DEM
This is the procedure suggested in Markus' book. My problem is that
I always end up with rather muddy-looking results. I have tried all
kinds of variations on this procedure, including different altitude
settings, recoloring the hillshade with a contrast-enhancing
greyscale color scheme before running r.his, etc. No real
improvement. As an example of what I'm shooting for, have a look at
this:
http://www.srh.noaa.gov/ridge/grk.shtml
Can anyone suggest a technique for achieving this quality?
- Jason
Jason Horn
Boston University Department of Biology
5 Cumington Street Boston, MA 02215
jhorn@bu.edu
office: 617 353 6987
cell: 401 588 2766
What happens if a big asteroid hits Earth? Judging from realistic simulations involving a sledge hammer and a common laboratory frog, we can assume it will be pretty bad.
- Dave Barry
This message has been scanned by Postini anti-virus software.
