[GRASSLIST:9198] XY to Projection
V.Transform cannot transform an XY location to
a Projected Location, say WGS-84.
However if it is a projected location… then V.Transform can Change to another projection.
So if a beginer
  1. Scans a map
  2. Spends days painstakingly to vectorise it…
And then it dawns upon him, that it must be projected…
HE HAD IT…
Developers please clear this lacuna.
ThanQ
Ravi Kumar
Yahoo! FareChase - Search multiple travel sites in one click.
Ok, so you have your unprojected vector layer digitised from an
unprojected raster map.
To project both now:
1. Project your raster map in Grass first.
2. Export the unprojected vector to a shapefile and import to the
destination location, where the background . It won't fit to your
projected raster - of couerse
In the "group" directory of you source location there is a file which
stores points you marked with i.poins when calibarting raster.
3.
  Dive into your grassdata/caves_xy/wlasnosc/group/wlasnosc
Use the same coordinates for
On ¶ro, 2005-11-23 at 04:09 -0800, RAVI KUMAR wrote:
However if it is a projected location.. then V.Transform can Change to
another projection.
So if a beginer
1. Scans a map
2. Spends days painstakingly to vectorise it..
And then it dawns upon him, that it must be projected..
HE HAD IT..
ThanQ
Ravi Kumar
______________________________________________________________________
W polskim Internecie s± setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.epf.pl/
Sorry for my previous email, my finger slipped and sent to soon.
To project both do:
1. Project your raster map in Grass first (i.group, i.target, i.points,
i.rectify).
destination location, where your projected raster is stored. The vector
won't fit yet to your projected raster - of course - but you will fix it
with v.transform in next setps.
3. In the "group" directory of you source location there is a file
"POINTS" which was created by i.points when calibarting raster. Format
those points according to NOTES from v.transform manual page. Save the
file in you home dir as, say, "ravi_points"
4. v.transform input=your_unprojected_vector output=projected_vector
pointsfile=~/ravi_points.
Does this work (honestly, I haven't tried)?
Maciek
ThanQ Maciek Sieczka
This works and we have been doing this to rescue, those vectors hurriedly done
without projecting the raster before vectorisation.
This is a solution, but
U export XY vector as a shape
Then import it into a projected location, to do the job.
I hope one day this will be simplified.
Thanks again
Ravi Kumar
To project both do:
    i.rectify).
    destination location, wher! e your projected raster is stored. The vector
    won’t fit yet to your projected raster - of course - but you will fix it
  3. In the “group” directory of you source location there is a file
    “POINTS” which was created by i.points when calibarting raster. Format
    file in you home dir as, say, “ravi_points”
Does this work (honestly, I haven’t tried)?
Maciek
Yahoo! Music Unlimited - Access over 1 million songs. Try it free.
