[GRASSLIST:9227] Re: V.drape issues
On Nov 27, 2005, at 11:49 AM, Michael Barton wrote:
Dylan,
I tried out v.drape yesterday, using Lorenzo Moretti’s build of 5 November. I tried to drape a vector of roads over an SRTM 30m dem.
My first attempt led to an error that said part of of the map was outside the defined region. The roads are for the entire state of Arizona and the SRTM was for only a part. So I made a vector of the region (co-terminous with the SRTM) and clipped the roads. Then I tried v.drape again using the roads clipped to the region. It generated the error below and seemed to hang. This is being run in an NAD27 UTM location.
v.drape input=roads_chevelon type=point,centroid,line,boundary,face,kernel rast=SRTM_u01_p036r036_filled method=nearest output=roads3d_chevelon
GRASS_INFO_WARNING(684,1): [SRTM_u01_p036r036_filled in aaa2005] - read request for row -18 is outside region
row = (int) G_northing_to_row (north, &window);
G_get_map_row (fd, maprow, row) < 0
DIAG: Region is: n=3.84547e+06 s=3.77074e+06 e=548379 w=472478
Data point is north=3.84602e+06 east=497700
GRASS_INFO_ERROR(684,2): Problem reading raster
GRASS_INFO_END(684,2)
Hi Michael, hope you don't mind me posting this to the GRASS list as well.
When I put this thing together, I built it around a model something like this:
loop through each line in vector
  loop through each point in line
    sample raster at this point with method x
    write sampled z value to vector[line][point]
Right now there is no checking for whether or not the raster being sampled actually exists at each point in the input vector, and whether each point is in the current region. If either one of these cases is true, then you will get an error like you mentioned. It looks like both of the errors you were having are related to reads outside of the current region.
Until I fix this heinous error, I would recommend working with a subset of your vector that fits completely within the extent of the elevation raster to be sampled. Also, make sure that the current region is just a hair smaller than the raster to be sampled and extent of the input vector-- as the sampling methods actually read a couple cells around the vector point.
Next I tried it with the Spearfish dataset. I tried to run v.drape on the roads vector file over the elevation.dem raster. Here is the result—pretty much the same as with my own data. (Note that the region was set to match the raster).
v.drape input=roads type=point,centroid,line,boundary,face,kernel rast=elevation.dem method=nearest output=roads3d1
[elevation.dem in PERMANENT] - read request for row 176 is outside region
DIAG: Region is: n=4.92651e+06 s=4.91444e+06 e=608416 w=589860
Data point is north=4.91406e+06 east=598566
Am I doing something wrong or does this indicate a bug?
This would be a bug. Sorry about that.
Dylan
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
