I found neccessary command to generate contours from DEM.
But after generating contours using r.contours. d.vect gives:
GRASS_INFO_WARNING(10978,1): coor files of vector 'elv2_cont3@orkun' is larger than it should be (14 bytes excess).
what can I do ?
regards
Ahmet Temiz
______________________________________
XamimeLT - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster@deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
On Tue, Nov 29, 2005 at 11:18:16AM +0200, orkun wrote:
Hello
what can I do ?
regards
Ahmet Temiz
Research Dept.
T.C.
degildir.
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/
OFFICE:
Department of Geoinformation Technologies
LDF MZLU v Brnì
Zemìdìlská 3
613 00 Brno
e-mail: xcepicky@node.mendelu.cz
URL: http://mapserver.mendelu.cz
Tel.: +420 545 134 514
Hello
what can I do ?
regards
Ahmet Temiz
thank you
v.build map=elv2_cont3 option=build
GRASS_INFO_WARNING(13283,1): coor files of vector 'elv2_cont3@orkun' is larger than it should be (14 bytes excess).
regards
