[GRASSLIST:925] CELL Maps to proper UTM Coordinates
Hi Folks
I was wondering how to get a scanned cell map so that its edges are in the
proper UTM coordinates so that it can be traced in v.digit, and later site
data added using the National grid.
Thanks
Kurt
On Fri, Aug 08, 2003 at 05:15:16AM +0100, Kurt Springs wrote:
Hi Folks
In short:
1) Import the map into a XY location
2) i.group, i.target to the UTM location
3) Then run i.points to reference the 4 corners (or anything nearby). You
need to know the coordinates of these 4 points which are then entered into
the terminal window of i.points.
Check the error with "Analyse" menu entry
4) Then i.rectify it with 1st order into the UTM location.
   An email arrives when the job is done.
4) leave the XY location, switch to the UTM location and verify
again with other GIS data.
Hope this helps
