[GRASSLIST:9286] Rotate raster
I have a number of rasters which are oriented with north at the right rather than at the top. Other than using i.rectify is there a simple way in GRASS to just rotate the image 90 degrees?
Nick Cahill
Well, if you need to rotate and don't need georeferenced images, you can use "Imagemagick" from the command line, so that you can insert it in a scrip for batch processing purposes.
Almost any image manipulation program, like "The GIMP" will do that...
Michele.
Nick Cahill
