[GRASSLIST:9289] number of rows in a table?
I need to find the number of rows in a table. I have some vector files that crash qgis, yet grass opens them fine. Looking at the dbf files, I suspect the the issue is the file size (20 - 30 MB). I wanted to check the number of rows and I've been looking through the db commands, unfortunately, so far all I have come across is using using db.describe to get the number of columns. Any suggestions?
Kirk
Aren't them 3D shapefiles by any chance? These are not supported in
QGIS. I have had such a problem - QGIS crashing instead of saying "3D
shapefile not supported". Reported to QGIS crew but no reply yet.
Just a wild guess.
If this is not the case, please report your issue in Qgis bugtracker.
Don't know what Grass command but dbview will do.
Maciek
W polskim Internecie s± setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.epf.pl/
Kirk
try this
echo "select count(*) from table" | db.select
this should return the number of rows in table.
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
Thanks for the suggestion. However, the command gives a DBF driver error:
GRASS 6.1.cvs (arrowhead_utm):~ > echo "select count(*) from allspecies83" | db.select
DBMI-DBF driver error:
SQL parser error in statement:
Error in db_open_select_cursor()
Am I missing something here?
Kirk
Kirk
try this
Dylan Beaudette
530.754.7341
>> suggestions?
as suggested, with dbview:
dbview -bt file.dbf | wc -l
perhaps with a grep thrown in and redirection to a > file.dat for subset
testing.
Hamish
