[GRASSLIST:9314] avcimport@Cygwin for v.in.e00
Hi listers,
Is it possible to install avcimport (to use v.in.e00) when GRASS is running under cygwin?
Ciao,
Luigi
Thanks Amish,
It was worth.
Unix is pushing Windows off my pc.
Ciao,
Luigi
It is worth a try to build it yourself from the .tgz package,
./configure
make
make install
Hamish
./configure
make
make install
Hamish
About .e00 files in GRASS,
I read in the GRASS book that .e00 files keep projection info. Does it mean that I can import them via v.in.e00 to any location and they will be reprojected?
Luigi
be reprojected?
Luigi
To reproject vector maps, use v.proj then.
