I have forgotten to write which versions I'm running:
proj: 4.4.9
geos: 2.1.4
gdal: 1.3.1
grass: 6.0.1
gdal-grass: 1.3.1
Georg Lösel wrote:
Hello Maik,
I have installed grass-6.0.1 and now i want to run "./configure
configure for GDAL ! Right?
Right!
--with-grass='/.../grass-6.0.1/lib/'
try --with-grass=/usr/local/grass-6.0.1/
Same problem. Is it possible that I've got the wrong version of one package?
HTH Georg
Greetings Maik
Since G_asprintf() function is now defined as a macro on some platforms having
asprintf(), test for G_asprintf() in GDAL configure fails. Open the GDAL
configure script and change all G_asprintf strings to G_version.
Hope it helps.
Huidae Cho
proj: 4.4.9
geos: 2.1.4
gdal: 1.3.1
grass: 6.0.1
gdal-grass: 1.3.1
Georg Lösel wrote:
>Hello Maik,
Right!
>HTH Georg
Greetings Maik
