[GRASSLIST:94] Errors compiling GRASS on SuSE 8.2 system
I am running into the following compiling GRASS 5.0.* on a SuSE
8.2 system.
*:~/incoming/grass5.0.2> cat error.log
GRASS GIS compilation log
Start of compilation: Wed May 21 01:53:08 PDT 2003
Errors:
Compilation error in module: src/misc/m.kappa (ignored)
Compilation error in module: src/raster/r.in.doq (ignored)
Compilation error in module: src/raster/wildfire (ignored)
Compilation error in module: src.garden/grass.postgresql (ignored)
Compilation error in module: src.contrib/GMSL/NVIZ2.2 (ignored)
End of compilation: Wed May 21 01:58:18 PDT 2003
The grass.postgresql error is a problem. Can someone explain what
the difference is between this new SuSE and the previous version
that would cause these errors?
John
8.2 system.
Errors:
Look for the actual error messages in the output from "make".
I got the same error messages on the SuSE 8.2 system.
did someone already figured out what went wrong and have any solution to
solve this problem??
Thanks for your help.
Johannes Bühler
On Wed, 21 May 2003 02:12:52 -0700
8.2 system.
Errors:
John
-- Johannes Buehler
   __O Feldstr. 45
=`\<, 14789 Greifswald
(=)/(=) johannes.buehler@uni-greifswald.de
----------- 03834 509307
