I am trying to import vmap0 files into GRASS using the very useful article by Marks Neteler in GRASS Newsletter 3, with Lorenzo Moretti's binaries on Mac OSX (Grass 6.1cvs of Nov. 22). I removed all the trailing periods, lowercased the filenames, but I can't get anything to read the files. When I run ogrinfo
[Nick:local/grasslib/bin] nick% ./ogrinfo -ro -summary gltp:/vrf/Users/nick/v0eur/vmaplv0/eurnasia 'polbnda@bnd(*)_area'
FAILURE:
Unable to open datasource `gltp:/vrf/Users/nick/v0eur/vmaplv0/eurnasia' with the following drivers.
-> ESRI Shapefile
-> UK .NTF
-> SDTS
-> TIGER
-> S57
-> MapInfo File
-> DGN
-> VRT
-> AVCBin
-> REC
-> Memory
-> CSV
-> GML
-> ODBC
-> OGDI
-> PostgreSQL
-> MySQL
Nothing I've tried seems to work. Has anybody had success with this? Is it possible that there is something wrong with the binaries? ogrinfo works fine with shapefiles, but doesn't seem to like VPFs.
Unless OGDI is hacked to behave like the examples (my GIS Libs package is, but Lorenzo uses his own build), that 'vrf' part must be spelled out so it can find the library. Normally the OGDI format code looks for the standard unix .so extension for libraries. Try using libvrf.dylib instead of vrf. If that doesn't work, it needs a location to find the library: set DYLD_LIBRARY_PATH in your shell to wherever Lorenzo has his libraries (I think it's /usr/local/grasslib/lib). For the tcsh shell:
setenv DYLD_LIBRARY_PATH /usr/local/grasslib/lib
FAILURE:
-> ESRI Shapefile
-> UK .NTF
-> SDTS
-> TIGER
-> S57
-> MapInfo File
-> DGN
-> VRT
-> AVCBin
-> REC
-> Memory
-> CSV
-> GML
-> ODBC
-> OGDI
-> PostgreSQL
-> MySQL
Just in case anyone else is in the same boat, I installed William Kyngesburye's gis libraries for Mac OSX, and these were able to convert vmap0 files to shapefiles successfully. I don't know why this didn't work with the library files installed by Lorenzo Moretti's installation of GRASS - but in any event, I'm happy.
It would be a big service for someone to convert all that data to shapefiles and make it available on the web. Is there an advantage to keeping it in the original VMAP0 format?
Nick Cahill
FAILURE:
-> ESRI Shapefile
-> UK .NTF
-> SDTS
-> TIGER
-> S57
-> MapInfo File
-> DGN
-> VRT
-> AVCBin
-> REC
-> Memory
-> CSV
-> GML
-> ODBC
-> OGDI
-> PostgreSQL
-> MySQL
>> FAILURE:
>> -> OGDI
"Users" is not lower case?
>> like VPFs.
Ok on linux, haven't tried on a mac. OGDI lib missing? you might need
to ask on the GDAL mailing list.
$ locate libvrf
a) who can host 2GB data for popular download? (bit torrent tracker?)
b) the license is public domain, but some ambiguous language has been
snuck in there. (some parts (c) Australian gov't; ERSI?)
like VPFs.
$ locate libvrf
It's there in Lorenzo's distribution - /usr/local/grasslib/lib. A non-standard location, but I would have thought that setting DYLD_LIBRARY_PATH would have done it, yet it didn't.
Looking back at the details of the hack I put in my distribution, I see that the standard OGDI makes 2 attempts to locate the vrf library (or whatever other gltp library) - first as specified, then as 'lib' + [libname] + '.so'. Both times use dlopen, which should use DYLD_LIBRARY_PATH. Nick - I wonder, did you try both setting DYLD_LIBRARY_PATH = /usr/local/grasslib/lib AND gltp:/libvrf.dylib/... together? (just to make sure, it wasn't clear in your offlist reply that you did them together)
