How can I export a site layer to an ascii file? I do it (s.out.ascii), but it only shows the result on the screen.
Thank you very much.
but it only shows the result on the screen. Thank you very much.
From the help page (at the very bottom):
http://grass.ibiblio.org/gdp/html_grass5/html/s.out.ascii.html
The output from s.out.ascii may be placed into a file by using the UNIX
redirection mechanism; e.g.:
s.out.ascii sites=archsites > out.file
s.out.ascii output may also be redirected into other programs; e.g.:
s.out.ascii sites=archsites | d.points color=red size=10 type=diamond
