[GRASSLIST:9425] DBMI errors with MySQL tables
Greetings,
Lately I have been having a lot of DBMI-related errors when working with
GRASS{6,6.1-CVS} vectors that have a MySQL table attached to them.
For example, I have a table that looks like this in MySQL:
gg_bulk_density_points;
| Field | Type | Null | Key | Default | Extra |
| cat | int(11) | YES | | NULL | |
| easting | int(11) | YES | | NULL | |
| northing | int(11) | YES | | NULL | |
| id | varchar(10) | YES | | NULL | |
| pedon_id | varchar(20) | YES | | NULL | |
| the_date | varchar(12) | YES | | NULL | |
| the_time | varchar(6) | YES | | NULL | |
| db_ring_hz1 | float | YES | | NULL | |
| db_ring_hz2 | float | YES | | NULL | |
| db_ring_hz3 | float | YES | | NULL | |
| db_ring_hz4 | float | YES | | NULL | |
| clay_capacity | float | YES | | NULL | |
| dominant_cover | varchar(20) | YES | | NULL | |
I have connected this table to a vector in GRASS{6,6.1-CVS} like this:
v.db.connect -o map=gg_bulk_density_points driver=mysql
table=gg_bulk_density_points database="host=localhost,dbname=test" key=cat
Running db.columns returns:
db.columns table=gg_bulk_density_points;
cat
easting
northing
id
pedon_id
the_date
the_time
db_ring_hz1
db_ring_hz2
db_ring_hz3
db_ring_hz4
clay_capacity
dominant_cover
Running db.select on this table gives:
echo "select * from gg_bulk_density_points" | db.select
dbmi: Protocol error
Running db.select on any other vector in this location, with a MySQL table
attached to it works fine...
Also: Trying to add this trouble vector+table in QGIS causes QGIS to die with
"DBMI error"
Any Ideas, as this is really starting to drive me nuts!
Could it possibly be a column type issue?
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
Ok , it looks like i have narrowed the problem down a bit:
GRASS6.1-CVS (today) + MySQL 4.1.15 server + MySQL 4.1.15 Client includes
If a table in MySQL connected to a GRASS vector has NULL values in ANY of the
columns, GRASS dies with a DBMI error.
I am pretty sure that this used to work. Were there any changes in the MySQL
API from version 4.0 -> 4.1 that may have caused things to break ?
It looks like this behavior was noted in BUG #3337:
http://intevation.de/rt/webrt?serial_num=3337&display=History
It would be a great help for any ideas on where to start hunting for this
bug...
Thanks in advance!
Dylan
On Monday 12 December 2005 12:30 pm, Dylan Beaudette wrote:
Greetings,
cat
easting
northing
id
pedon_id
the_date
the_time
db_ring_hz1
db_ring_hz2
db_ring_hz3
db_ring_hz4
clay_capacity
dominant_cover
with "DBMI error"
Dylan Beaudette
530.754.7341
On Monday 12 December 2005 04:30 pm, Hamish wrote:
On Mon, 12 Dec 2005 15:40:25 -0800
> > DBF has a 10 char limit to names. Maybe a test for this this is
> > polluting the mysql driver somehow? try making the above four
> > different in the first 10 chars?
> Thanks for the quick feedback Hamish. I am not sure that I understand
> what you are suggesting... Do you mean that 10+ character names in
> MySQL are causing the problems? I don't think this is the case, as
> when i replace my NULL values with empty strings or '0' everything
> works fine- even with the long names.
> is that what you meant?
Yea, it probably isn't that, but I mentioned it as I noticed in those
four the first 10 chars are not unique. I know that shouldn't affect it,
but you never know...
Probably the NULL handling has to be followed in a debugger to see where
it goes wrong. Have you run GRASS with `g.gisenv set="DEBUG=5"` to
narrow down when the DBMI error happens?
Hamish
Thanks for the tips. Here are the results when I up' the debug level:
echo "select *" | db.select table=db_null_test
D2/5: opendir /usr/local/grass-6.1.cvs/driver/db/
D3/5: db_driver_open_database() driver = mysql database definition =
'host=localhost,dbname=test'
D3/5: parse_conn : host=localhost,dbname=test
D3/5: token 0 : host=localhost
D3/5: token 1 : dbname=test
D3/5: host = localhost, port = 0, socket = (null), dbname = test, user =
(null), password = (null)
D3/5: db_get_login(): mysql host=localhost,dbname=test
D3/5: file = /home/dylan/.grasslogin6
D3/5: ret = 4 : mysql host=localhost,dbname=test xxx xxx
D3/5: ret = 4 : mysql test@localhost xxx xxx
D3/5: load_table()
D3/5: load_table() - not loaded
D3/5: load_table() - number of cols is 1
D3/5: load_table() - number of cols is 2
Looks like something is breaking in the load_table() function ?
Hmmmmm...
Poking around in this source code for CVS, the following matches look
interesting:
grep -n -R "load_table()" .
./db/drivers/mysql/table.c:113: G_debug(3, "load_table()");
./db/drivers/mysql/table.c:117: G_debug(3, "load_table() - not loaded");
./db/drivers/mysql/table.c:193: G_debug(3, "load_table() - number of cols is
%d", db.tables[t].ncols);
Not sure how to interpret these debug messages...
Further ideas? maybe we are getting closer...?
Dylan Beaudette
530.754.7341
The mysql driver is a quick hack which was written by somebody as
copy-and-paste from dbf which is completely wrong (loading tables
to memery instead of mysql_fetch_field_direct fro each db_fetch etc.)
+ practicaly it is not maintained few years.
It should be completely rewritten.
Radim
> loaded"); ./db/drivers/mysql/table.c:193: G_debug(3, "load_table() -
> number of cols is %d", db.tables[t].ncols);
Radim
Radim,
Thank you for the information on this. Any ideas on what it would take to get
a better functioning MySQL driver? I am not sure that I would have the time
or technical ability to do it myself- but I would be quite willing to help
out on the development of a more robust driver. I use MySQL for all of my
research, and if the interface to GRASS is less than stellar - then I need to
make some choices. I have a rather complete reference for the MySQL 4.1 C API
that might help out.
From my perspective it is quite a daunting task do try and accomplish on my
own.
Anyone else interested in helping?
Dylan Beaudette
530.754.7341
Presumably you can access MySQL databases using the ODBC driver?
Indeed. I hadn't thought about this. Does anyone have an idea as to how robust
the ODBC driver is when connecting to MySQL ?
Thanks!
Dylan Beaudette
530.754.7341
