[GRASSLIST:9442] Re: Problem installing gdal-grass-1.3.1
I had a look on the "Makefile"
Line 49:
GLIBNAME = gdal_GRASS.so
OLIBNAME = ogr_GRASS.so
default: $(GLIBNAME) $(OLIBNAME)
install: default
       install -d $(AUTOLOAD_DIR)
       cp $(GLIBNAME) $(AUTOLOAD_DIR)
       cp $(OLIBNAME) $(AUTOLOAD_DIR)
The error occures when trying to copy gdal_GRASS.so to $(AUTOLOAD_DIR).
I can't find gdal_GRASS.so . But why isn't it where it should be. Where should I find this file? Is it from gdal_grass-package or from another package? Where is it initialised?
Anybody an idea?
Greetings
Maik
Maik Trömel wrote:
Thanks for your support,
Line 49:
install: default
Anybody an idea?
Greetings
Maik
Hamish wrote:
installing GRASS-6.0.1 from tar.gz I got a problem with
gdal-grass-1.3.1.
To begin with, try the gdal-grass-1.3.1.1 version. (there was a bug in
1.3.1 release)
http://www.gdal.org/dl/gdal-grass-1.3.1.1.tar.gz
I tried it: Same problem.
Hamish
Hernán De Angelis wrote:
Maik,
Are your GRASS and GDAL in standard directories? If not, if you only did
./configure
without specifying
--with-grass=/your/path/to/grass/
and
--with-gdal=/your/path/to/gdal/bin/gdal-config
I ran it this way. I think thats not the problem.
it will never work. In that case you might also need to make the libraries accesible in /etc/ld.so.conf (and run "ldconfig" as root after that)
I have updated /etc/ld.so.conf and run ldconfig. It has no influence on the problem.
Hope this helps
Hernán
El Lunes 12 Diciembre 2005 11.13, Maik Trömel escribió:
Hello GRASS-Users,
installing GRASS-6.0.1 from tar.gz I got a problem with gdal-grass-1.3.1.
I run:
./configure -> no problem
make -> no problem
make install (as root):
install -d /usr/lib/gdalplugins
cp gdal_GRASS.so /usr/lib/gdalplugins
cp: cannot stat `gdal_GRASS.so': No such file or directory
make: *** [install] Error 1
Anybody an idea what the problem could be?
Thanks for help!
Maik
gdal-grass-1.3.1.
1.3.1 release)
Hamish
Maik,
./configure
without specifying
and
Hope this helps
Hernán
Hello GRASS-Users,
I run:
make -> no problem
Thanks for help!
Maik
Maik,
I did my installation last weekend. I did the following configure:
./configure --prefix=/usr/local/gdal-grass-1.3.1
--with-gdal=/usr/local/gdal/bin/gdal-config
--with-grass=/usr/local/grass-6.1.0/grass-6.1.cvs
and everything went smoothly. In my box, these two files were installed in:
/usr/local/gdal-1.3.1/lib/gdalplugins
I am not an expert but I guess that in your case something was left from a
previous failed attempt to install. I think it would be a good idea to do a
"make distclean" on the source directory of gdal-grass and start a new build.
Good luck!
Hernán
Line 49:
install: default
Anybody an idea?
Greetings
Maik
> Line 49:
> install: default
> Anybody an idea?
> Greetings
> Maik
>>>> gdal-grass-1.3.1.
>>> 1.3.1 release)
>>> Hamish
>>> Maik,
>>> did
>>> ./configure
>>> without specifying
>>> and
>>> after that)
>> on the problem.
>>> Hope this helps
>>> Hernán
>>>> Hello GRASS-Users,
>>>> gdal-grass-1.3.1.
>>>> I run:
>>>> make -> no problem
>>>> Thanks for help!
>>>> Maik
>>> gdal-grass-1.3.1.
>> 1.3.1 release)
>> Hamish
>> Maik,
>> ./configure
>> without specifying
>> and
>> after that)
> on the problem.
>> Hope this helps
>> Hernán
>>> Hello GRASS-Users,
>>> gdal-grass-1.3.1.
>>> I run:
>>> make -> no problem
>>> Thanks for help!
>>> Maik
Hernán De Angelis
hernan.deangelis@glocalnet.net
Alle 17:34, martedì 13 dicembre 2005, Hernán De Angelis ha scritto:
Maik,
build.
Good luck!
Hernán
> Line 49:
> install: default
> Anybody an idea?
> Greetings
> Maik
> > Line 49:
> > install: default
> > Anybody an idea?
> > Greetings
> > Maik
> >>>> gdal-grass-1.3.1.
> >>> in 1.3.1 release)
> >>> Hamish
> >>> Maik,
> >>> did
> >>> ./configure
> >>> without specifying
> >>> and
> >>> after that)
> >> on the problem.
> >>> Hope this helps
> >>> Hernán
> >>>> Hello GRASS-Users,
> >>>> gdal-grass-1.3.1.
> >>>> I run:
> >>>> make -> no problem
> >>>> Thanks for help!
> >>>> Maik
> >>> gdal-grass-1.3.1.
> >> 1.3.1 release)
> >> Hamish
> >> Maik,
> >> did ./configure
> >> without specifying
> >> and
> >> after that)
> > on the problem.
> >> Hope this helps
> >> Hernán
> >>> Hello GRASS-Users,
> >>> gdal-grass-1.3.1.
> >>> I run:
> >>> make -> no problem
> >>> Thanks for help!
> >>> Maik
I tryed with your same configure and after a DEEP clean, but the error it's
the same...
Thx
Luca
"Esperienza è il nome che ciascuno da ai suoi errori. (O. Wilde) "
GENTOO-GIS Development Team
jabber: casagrande@jabber.linux.it
I found the "gdal-GRASS.so"-file. It's in "/usr/local/lib". I changed the filename in the Makefile
"GLIBNAME = gdal_GRASS.so" to "GLIBNAME= /usr/local/lib/gdal_GRASS.so"
The error
install -d /usr/local/lib/gdalplugins
cp gdal_GRASS.so /usr/local/lib/gdalplugins
doesn't occure any longer. But therefore I get the same error with the next file "ogr_GRASS.so":
cp /usr/local/lib/gdal_GRASS.so /usr/local/lib/gdalplugins
cp /usr/local/lib/ogr_GRASS.so /usr/local/lib/gdalplugins
cp: cannot stat `ogr_GRASS.so': No such file or directory
make: *** [install] Fehler 1
But again I can't find the file.
Probably someone has an idea.
Greetings Maik
Maik,
build.
Good luck!
Hernán
Line 49:
install: default
Anybody an idea?
Greetings
Maik
Line 49:
install: default
Anybody an idea?
Greetings
Maik
gdal-grass-1.3.1.
in 1.3.1 release)
Hamish
Maik,
did
./configure
without specifying
and
after that)
on the problem.
Hope this helps
Hernán
Hello GRASS-Users,
gdal-grass-1.3.1.
I run:
make -> no problem
Thanks for help!
Maik
gdal-grass-1.3.1.
1.3.1 release)
Hamish
Maik,
did ./configure
without specifying
and
after that)
on the problem.
Hope this helps
Hernán
Hello GRASS-Users,
gdal-grass-1.3.1.
I run:
make -> no problem
Thanks for help!
Maik
I tryed with your same configure and after a DEEP clean, but the error it's the same...
Thx
Luca
Alle 09:36, martedì 20 dicembre 2005, Maik Trömel ha scritto:
Hi Luca,
have you fixed to problem installing gdal-grass?
Greetings Maik
>>Maik,
>> in:
>> a previous failed attempt to install. I think it would be a good idea to
>> do a "make distclean" on the source directory of gdal-grass and start a
>> new build.
>>Good luck!
>>Hernán
>>>Line 49:
>>>install: default
>>>Anybody an idea?
>>>Greetings
>>>Maik
>>>>Line 49:
>>>>install: default
>>>>Anybody an idea?
>>>>Greetings
>>>>Maik
>>>>>>>gdal-grass-1.3.1.
>>>>>>in 1.3.1 release)
>>>>>>Hamish
>>>>>>Maik,
>>>>>>did
>>>>>>./configure
>>>>>>without specifying
>>>>>>and
>>>>>>after that)
>>>>>on the problem.
>>>>>>Hope this helps
>>>>>>Hernán
>>>>>>>Hello GRASS-Users,
>>>>>>>gdal-grass-1.3.1.
>>>>>>>I run:
>>>>>>>make -> no problem
>>>>>>>Thanks for help!
>>>>>>>Maik
>>>>>>gdal-grass-1.3.1.
>>>>>1.3.1 release)
>>>>>Hamish
>>>>>Maik,
>>>>>did ./configure
>>>>>without specifying
>>>>>and
>>>>>after that)
>>>>on the problem.
>>>>>Hope this helps
>>>>>Hernán
>>>>>>Hello GRASS-Users,
>>>>>>gdal-grass-1.3.1.
>>>>>>I run:
>>>>>>make -> no problem
>>>>>>Thanks for help!
>>>>>>Maik
> it's the same...
>Thx
>Luca
Solved with manual operation...I think someone had to fix the install part of
gdal-grass-1.3.1.1
Thx for the help
Luca
