[GRASSLIST:9448] projection of vector points from v.in.ascii
Thanks to Maris and Jose for the references on v.surf.rst.
I have an n-th issue:
The ascii file with Lat/Long that I used via v.in.ascii to produce the interpolated raster, needs to be first imported to a LatLong location and then reprojected to the Lambert Conformal Conic/NAD83 location where I have map files. Is this right? Should I be able to import a vector with latitude and longitude to any location or not?
Luigi
yes, after importing into the LL location, restart in the LCC/83
location and run v.proj.
location or not?
Only via v.proj, not directly..
But you can pass it through PROJ4's cs2cs first. see the $IN_PROJ,
$OUT_PROJ, and cs2cs bits in the v.in.garmin script; ie (generally) to
go from WGS84 lon/lat to current projection:
IN_PROJ="+proj=longlat +towgs84=0.000,0.000,0.000"
OUT_PROJ="`g.proj -jf`"
cs2cs -f %.7f $IN_PROJ +to $OUT_PROJ < infile.txt > outfile.txt
If source projection is not LL/WGS84, use g.proj to get correct input
string.
cs2cs is probably already installed on your system.
Hamish
Thanks Amish,
I gave it a try but cs2cs does not seem to be able to process the entire table with coordinates and point values.
What I am trying to do is to automate the commands I have used to process the ascii output file of the population model (i.e., import, reproject, interpolate, clip, drape over a shaded relief, etc.) by using a script. I am missing some steps:
- How can I switch between locations with a shell script (so far I am able to start grass with the correct location/mapset: not much)?
- Is it better to run the script from the bash/cygwin shell or from the grass shell?
- Is there a general approach to GRASS scripts and where should look for reference?
Luigi
location or not?
string.
Hamish
