[GRASSLIST:9472] Re: Problem installing gdal-grass-1.3.1
Its still the same problem. But i'm running another Version (6.0.1). There is no "grass-6.x.x.cvs in /usr/local/grass-6.0.1/. But I don't think that this is the problem.
@Luca: It is doing good, not to be alone :stuck_out_tongue_winking_eye:
Please post it, when you get it on your own.
Luca Casagrande wrote:
Alle 17:34, martedì 13 dicembre 2005, Hernán De Angelis ha scritto:
Maik,
I did my installation last weekend. I did the following configure:
./configure --prefix=/usr/local/gdal-grass-1.3.1
--with-gdal=/usr/local/gdal/bin/gdal-config
--with-grass=/usr/local/grass-6.1.0/grass-6.1.cvs
and everything went smoothly. In my box, these two files were installed in:
/usr/local/gdal-1.3.1/lib/gdalplugins
I am not an expert but I guess that in your case something was left from a
previous failed attempt to install. I think it would be a good idea to do a
"make distclean" on the source directory of gdal-grass and start a new
build.
Good luck!
Hernán
El Martes 13 Diciembre 2005 15.49, Maik Trömel escribió:
I had a look on the "Makefile"
Line 49:
GLIBNAME = gdal_GRASS.so
OLIBNAME = ogr_GRASS.so
default: $(GLIBNAME) $(OLIBNAME)
install: default
      install -d $(AUTOLOAD_DIR)
      cp $(GLIBNAME) $(AUTOLOAD_DIR)
      cp $(OLIBNAME) $(AUTOLOAD_DIR)
The error occures when trying to copy gdal_GRASS.so to $(AUTOLOAD_DIR).
I can't find gdal_GRASS.so . But why isn't it where it should be. Where
should I find this file? Is it from gdal_grass-package or from another
package? Where is it initialised?
Anybody an idea?
Greetings
Maik
Maik Trömel wrote:
Thanks for your support,
Line 49:
install: default
Where should I find this file? Is it from gdal_grass-package or from
another package? Where is it initialised?
Anybody an idea?
Greetings
Maik
Hamish wrote:
installing GRASS-6.0.1 from tar.gz I got a problem with
gdal-grass-1.3.1.
To begin with, try the gdal-grass-1.3.1.1 version. (there was a bug
in 1.3.1 release)
http://www.gdal.org/dl/gdal-grass-1.3.1.1.tar.gz
I tried it: Same problem.
Hamish
Hernán De Angelis wrote:
Maik,
Are your GRASS and GDAL in standard directories? If not, if you only
did
./configure
without specifying
--with-grass=/your/path/to/grass/
and
--with-gdal=/your/path/to/gdal/bin/gdal-config
I ran it this way. I think thats not the problem.
it will never work. In that case you might also need to make the
libraries accesible in /etc/ld.so.conf (and run "ldconfig" as root
after that)
I have updated /etc/ld.so.conf and run ldconfig. It has no influence
on the problem.
Hope this helps
Hernán
El Lunes 12 Diciembre 2005 11.13, Maik Trömel escribió:
Hello GRASS-Users,
gdal-grass-1.3.1.
I run:
./configure -> no problem
make -> no problem
make install (as root):
install -d /usr/lib/gdalplugins
cp gdal_GRASS.so /usr/lib/gdalplugins
cp: cannot stat `gdal_GRASS.so': No such file or directory
make: *** [install] Error 1
Anybody an idea what the problem could be?
Thanks for help!
Maik
gdal-grass-1.3.1.
To begin with, try the gdal-grass-1.3.1.1 version. (there was a bug in
1.3.1 release)
Hamish
Maik,
did ./configure
without specifying
and
after that)
on the problem.
Hope this helps
Hernán
Hello GRASS-Users,
gdal-grass-1.3.1.
I run:
make -> no problem
Thanks for help!
Maik
I tryed with your same configure and after a DEEP clean, but the error it's the same...
Thx
Luca
