hello
what can I do to overcome the problem ?
v.to.rast input=jgenel1 layer=1 output=jgenel1 use=attr column=yas rows=4096
Loading vector information ...ERROR: Column type not supported by db_select_to_array()
regards
Ahmet Temiz
______________________________________
XamimeLT - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster@deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
The column must be of integer type...
which type is your "yas" column???
regards
Il giorno gio, 15-12-2005 alle 11:33 +0200, orkun ha scritto:
hello
rows=4096
regards
Ahmet Temiz
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini@unipg.it
ivan.marchesini@gmail.com
tel: +39(0)755853760
fax: +39(0)755853756
