hi to all,
I have a problem with importing ascii points into grass:
I need to import a vector ascii map into grass, grass is connected to a
.dbf database. Following the manpage, it seems that the v.in.ascii
command is the same whatever is the database I want to connect to, so I
type:
On Thu, Dec 15, 2005 at 02:06:45PM +0100, Francesco Mirabella wrote:
hi to all,
type:
> type:
> v.in.ascii input=ascii_file.txt output=prova_dbf fs=tab columns='cat integer, x double precision, y double precision, cdp_number varchar(20), line_name varchar(20), acquisition_year varchar(20)' x=2 y=3 cat=1
> but I get:
> DBMI-DBF driver error:
> Incompatible value type.
> Error in db_execute_immediate()
> ERROR: Cannot insert values: insert into prova_ar_dbf values ( 1,
> 11.919589, 43.679116, 101, 'ar315', 1981)
I think that cdp_number and acquisition_year are of integer type, not varchar.
At least they are not quoted.
I tried with integer, but I get the same error....
Francesco
> GRASS 6.0.1 (fogli_geo):~ >
> I think it is related to the names that I want for the columns of the
> table, but I can't see what to do.
> can someone help??
> cheers,
> Francesco
I found the same problem described below, can someone say if and how it
was solved?
many thanks to all of you,
cheers
Francesco
> hi to all,
> type:
> but I get:
> can someone help??
> cheers,
> Francesco
Francesco Mirabella,
Structural Geology and Geophysics
address: University of Perugia,
Dipartimento di Scienze della Terra
Piazza Universita', 1 06100 Perugia (Italy)
tel: ++39.(0)75.585 2651
fax: ++39.(0)75.585 2603
e-mail: mirabell@unipg.it
web: http://www.unipg.it/~mirabell/
it was solved?
> > to a .dbf database. Following the manpage, it seems that the
> > v.in.ascii command is the same whatever is the database I want to
> > connect to, so I type:
> > but I get:
> not varchar. At least they are not quoted.
try:
v.in.ascii input=ascii_file.txt output=prova_dbf fs=tab x=2 y=3 cat=1 \
columns='cat integer, x double, y double, cdp_number integer, line_name varchar(20), acquisition_year integer'
i.e. change varchar() to integer in the integer only columns. I had
thought that Radim had modified v.in.ascii to let column types defined
in columns= override what was scanned. Maybe not, or maybe this is only
in the 6.1 development branch.
that worked, I previously tried INT4, thinking that it was the same, but
it is not.
Now it looks ok
cheers,
Francesco
> it was solved?
> > > but I get:
try:
Hamish
