[GRASSLIST:9528] Replacement for r.volume
Hello
What is the replacement command for r.volume, which doesn't seem to exist
in GRASS 6.0 ?
Many thanks
Roy
Roy Sanderson
Institute for Research on Environment and Sustainability
Devonshire Building
University of Newcastle
Newcastle upon Tyne
NE1 7RU
United Kingdom
Tel: +44 191 246 4835
Fax: +44 191 246 4999
http://www.ncl.ac.uk/environment/
r.a.sanderson@newcastle.ac.uk
exist in GRASS 6.0 ?
I just added it to the 6.1-cvs. I haven't tested but it will probably
run. :slight_smile: (at least it builds ok)
The centroid ouput code needs updating to the new vector points format &
it needs some DB code added for creating the linked attribute table.
Centroid output is optional, so worse case we just disable that code if
we decide to do a 6.2 stable release and it isn't fixed yet.
hopefully someone who knows how to use it can take it from here.
Hamish
