Hi Roy,
i had the same problem.
Here is my solution:
- checkout the region's resolution
- calculate the area of one cell (resx * resy)
- run r.stats for your surface (dem)
- multiply the area of a cell with the sum of the surface's values
Michael
Roy Sanderson wrote:
> Hello
> What is the replacement command for r.volume, which doesn't seem to exist
> in GRASS 6.0 ?
> Many thanks
> Roy
> Roy Sanderson
> Institute for Research on Environment and Sustainability
> Devonshire Building
> University of Newcastle
> Newcastle upon Tyne
> NE1 7RU
> United Kingdom
> Tel: +44 191 246 4835
> Fax: +44 191 246 4999
> http://www.ncl.ac.uk/environment/
> r.a.sanderson@newcastle.ac.uk
Michael Fecht
Freisingstraße 2
A6020 Innsbruck
+43 (0)650 8131923
