[GRASSLIST:955] live GRASS/GPS interface
I've been thinking about how to do a real-time GRASS/GPS interface.
General idea is to have a GPS feeding NMEA statements into the laptop's
serial port, and have a program running in the background which parses
the statement, feeds it through PROJ, and appends the result into a
site_lists/gps_track file, as well as replacing the single point in a
site_lists/latest_postion sites file. Lat-Lon, Time, COG, SOG, other GPS
messages would be written to the site's comments. (or even run r.what
for that position and use that in the comment string)
e.g.:
d.rast topo
d.vect contours
d.sites gps_track color=red size=1
d.sites latest_position color=red size=3
d.site.labels latest_position attr=...
then, d.redraw or d.pan should update the track whenever I update the
monitor.
I suppose you could also have a background process which runs:
g.region sites=latest_postion
d.redraw
every few minutes if you wanted. It could even do a little math so it
only redraws when latest_postion is outside WIND ...
I suppose a 5.1-style GUI could be written to control all this..
Not very clean, but I think it should work.
I've already written the NMEA parser, output to the sites format is
trivial, but I'm not sure about how to go about the serial port daemon
(although I am pretty familiar with RS232 i/o).
Anybody have thoughts or suggestions before I dive into the gpsdrive
code?
Hamish
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
e.g.:
d.rast topo
d.vect contours
monitor.
d.redraw
I have been doing some similar stuff (not directly to grass, I need some
ohter processing first), and found it convenient to make a gpsd client.
This allows the use of a remote GPS, or a local GPS, and allows you to
forget about managing the serial port, and also allows multiple programs
to access the data.
Buchan
|--------------Another happy Mandrake Club member--------------|
Buchan Milne Mechanical Engineer, Network Manager
Cellphone * Work +27 82 472 2231 * +27 21 8828820x202
Stellenbosch Automotive Engineering http://www.cae.co.za
GPG Key http://ranger.dnsalias.com/bgmilne.asc
1024D/60D204A7 2919 E232 5610 A038 87B1 72D6 AC92 BA50 60D2 04A7
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQE/PJ3drJK6UGDSBKcRAtXfAJ9dMaaD8ES69oKnqMAG+2TqW9/zBwCeIDJA
9KfkStk6kVX5Bl6zsJVQbk0=
=N8Ho
-----END PGP SIGNATURE-----
Please click on http://www.cae.co.za/disclaimer.htm to read our
e-mail disclaimer or send an e-mail to info@cae.co.za for a copy.
e.g.:
d.rast topo
d.vect contours
monitor.
d.redraw
code?
I think that what you described (write to site files + d.sites etc.)
can be easily done in few minutes but it is far from optimal solution.
I would suggest PostGIS as data store (as ready for use solution for
simultaneous read/write access) and QGIS as interface.
It would require some simple extension for vector layer in QGIS
(periodically zoom to vector). QGIS can work with both PostGIS
and GRASS data. GRASS can also access PostGIS data.
Radim
> laptop's serial port, and have a program running in the background
> which parses the statement, feeds it through PROJ, and appends the
> result into a site_lists/gps_track file, as well as replacing the
> single point in a site_lists/latest_postion sites file. Lat-Lon,
> Time, COG, SOG, other GPS messages would be written to the site's
> comments. (or even run r.what for that position and use that in the
> comment string)
It took me more than a few minutes, and yes, it is a far from optimal
solution, but hey, it works! It's just a quick proof of concept bash
script and should be rewritten in C using the GRASS projection & sites
libraries once I figure them out. Feel free to give it a try:
http://bambi.otago.ac.nz/hamish/m.realtime_gps.sh
While it should work with any GPS or LORAN C system that can send NMEA
sentences to the serial port, I tested it out with a Garmin 48 handheld.
You'll need to modify the USER_PROJ= line at the top for your particular
dataset, and set the sample frequency as needed (currently 30 seconds).
The "current location" marker will show a time-stamp, and other text such
as underlying raster map values can be displayed as well (currently GPS
altitude).
Needs gpsd, netcat, and cs2cs. (see comments in the script)
Two thoughts --
As the present sites format is due for retirement, PostGIS or GRASS
5.1(5.7) vector-points format is the preferable long term solution.
On the other hand, I'd think this would be quite useful tool for the
handheld-PDA GRASS people, offering a bit more power than pyGPS does
currently. Has anyone gotten PostGIS or GRASS 5.1(5.7) with its database
needs working on a handheld? Is this an issue? Does QGIS run on
handhelds yet? Does this script+QGIS offer anything over pyGPS?
regards,
Hamish
