It comes with hdr and ers files (attached) but GRASS opens the img
data as unprojected.
I've tried setting the projection and datum manually and then
importing but I'm just getting myself horribly confused.
I managed to find a file online that defined the MRWORLD projection as:
MRWORLD:PROJCS["MRWORLD",PROJECTION["Mercator_1SP"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",0],PARAMETER["scale_factor",1],PARAMETER["false_easting",0],PARAMETER["false_northing",20000000]]
Alternatively, if there is a global topography (including sea floor)
dataset which is more easily included with correct projection and
datum then feel free to point me to that.
With a little work you can probably get that data loaded, but for
something with detailed instructions try the ETOPO2 dataset. See the
article in GRASSNews vol 1. http://grass.ibiblio.org/newsletter/index.php
ETOPO2 includes the Smith & Sandwell satellite altimeter derived
bathymetry.
On 12/19/05, Hamish <hamish_nospam@yahoo.com> wrote:
> I'm trying to georeference the global topography data here:
> ftp://topex.ucsd.edu/pub/global_topo_2min
bathymetry.
Hamish
Carlos Henrique Grohmann - Guano
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
