When I try to run "d.mon start=PNG" the error doesn't occure. But there is another error:
after running
d.mon start=PNG
d.mon select=PNG
d.rast geom_summe_s_filt_country
d.vect map=grass_country
d.mon stop=PNG
PNG: GRASS_TRUECOLOR status: FALSE
PNG: collecting to file: map.png,
GRASS_WIDTH=640, GRASS_HEIGHT=480
Graphics driver [PNG] started
100%
Monitor 'PNG' terminated
ERROR - eof from graphics monitor.
Maik
Maik Trömel wrote:
I tried it out. The problem is, that its not possible to start a display.
When I run "d.mon start=x0" I get an error:
ERROR: Graph_Set: can't open Display
No socket to connect to for monitor <x0>.
Problem selecting x0. Will try once more
Any idea what the problem could be?
Maik
Michael Barton wrote:
Check out the d.out.file script (or it's predecessor, d.out.png) that I
wrote and is included with GRASS. This will export whatever is on the
current monitor to a png (or other formats if you have gdal). Add d.mon and
d.rast and/or d.vect and you can script the creation of a map and its export
to png.
Michael
______________________________
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
Date: Thu, 15 Dec 2005 11:28:48 +0100
To: GRASSLIST <GRASSLIST@baylor.edu>
Subject: [GRASSLIST:9498] script for creating map
Hello Grass-Users,
I want to write a script that creates a map as a png-file. I know how to
make it by hand. But when I try to script it, it doesn't work because I
can't open a monitor. Is there a possibility to create a map with a script.
If "yes". How can I do this.
Thanks for you help.
Greetings
Maik
The following script works when called from the command line of GRASS 6.0.0 running under cygwin on windows NT. It saves the x0 monitor to a .png file.
Ciao,
Luigi
----script begins----
#!/bin/bash
d.mon start=x0
d.vect map=vectorName
d.out.png output=mapName
d.mon stop=x0
----script ends------
after running
d.mon start=PNG
d.mon select=PNG
d.mon stop=PNG
100%
Maik
Maik
to png.
Michael
USA
Hello Grass-Users,
Greetings
Maik
