[GRASSLIST:9588] v.buffer: area boundary around line? Wanted: howto!
Hi List,
I tried to create a new area boundary around a line theme. Thought it would
be easy to do it like this:
v.buffer in=ausschnitt out=buff_ausschnitt bufcol=gesamtbr type=boundary
But GRASS won't create a new theme. After that, I tried to first create a
line buffer theme (works fine) and then convert it to a area boundary theme
using v.type. However, the new area boundary theme does not have the shape
of the line buffer theme.
BTW, the line theme looks like this (street network):
    | | ...but I get s.th. XXXXXXXXXXXX
    | | like this: XXXXXXXXXXXX
  -------------- XXXXXXXXXXXX (area inside)
I would greatly appreciate to receive some hints...
Best wishes,
Wolfgang
GMX DSL-Flatrate 1 Jahr kostenlos* + WLAN-Router ab 0,- Euro*
Bis 31.12.2005 einsteigen! Infos unter: http://www.gmx.net/de/go/dsl
Am Mittwoch, 21. Dezember 2005 11:22 schrieb Wolfgang Qual:
Hi List,
I also tried with the spearfish location and a CVS snapshot from today and got
similar strange results, where the lines (roads) describe a closed ring.
v.buffer in=roads out=roadsbuf buffer=20 type=line
  Otto
Best wishes,
Wolfgang
GDF Hannover - Solutions for spatial data analysis and remote sensing
Office Hannover - Mengendamm 16d - D - 30177 Hannover
Internet: www.gdf-hannover.de, Email: info@gdf-hannover.de
Phone : ++49.(0)511.39088507, Fax: ++49.(0)511.39088508
Hi Otto, hi list.
Sorry, I think I was too fast...:
If I *do not specify "type"* in the command for v.buffer (v.buffer
in=ausschnitt out=buff_ausschnitt bufcol=gesamtbr)
I do get a correct result. I can add this vector to my QGIS-Map (Layer
1_polygon) - works.
However: how can I display this in GRASS (d.mon, d.vect)? If I try d.vect,
the area inside the ring is also displayed!
Wolfgang
Buffer is drawn around the feature (line).
--- Ursprüngliche Nachricht ---
Von: Otto Dassau <dassau@gdf-hannover.de>
An: "Wolfgang Qual" <Wolfgang.Qual@gmx.net>
Kopie: grasslist@baylor.edu
Betreff: Re: [GRASSLIST:9588] v.buffer: area boundary around line? Wanted:
howto!
Datum: Wed, 21 Dec 2005 12:17:50 +0100
> Hi List,
would
got
  Otto
a
theme
shape
> Best wishes,
> Wolfgang
10 GB Mailbox, 100 FreeSMS/Monat http://www.gmx.net/de/go/topmail
+++ GMX - die erste Adresse für Mail, Message, More +++
Am Mittwoch, 21. Dezember 2005 13:19 schrieb Wolfgang Qual:
Hi Otto, hi list.
the problems I described still exist with the spearfish dataset:
it doesn't make a difference in the result.
  Otto
1_polygon) - works.
Wolfgang
> Wanted: howto!
> > Hi List,
> Hi,
> would
> > type=boundary
> and got
> Otto
> a
> theme
> shape
> > inside)
> > Best wishes,
> > Wolfgang
Hello Otto,
so you do not have the possibility to choose layer property "1_polygon" in
the "add grass vector layer dialog" of QGIS? I just tried the same command
(v.buffer in=roads out=roadsbuf buffer=20) and it looks ok. If I choose
0_polygon, only the area between the roads is drawn by QGIS.
Best regards,
Wolfgang
Betreff: [GRASSLIST:9591] Re: v.buffer: area boundary around line? Wanted:
howto!
Datum: Wed, 21 Dec 2005 13:45:47 +0100
> Hi Otto, hi list.
  Otto
> 1_polygon) - works.
d.vect,
> Wolfgang
> > Wanted: howto!
> > > Hi List,
> > Hi,
it
> > would
> > > type=boundary
> > and got
ring.
> > Otto
create
> > a
boundary
> > theme
> > shape
> > > inside)
> > > Best wishes,
> > > Wolfgang
Am Mittwoch, 21. Dezember 2005 15:17 schrieb Wolfgang Qual:
Hello Otto,
Hi
Sorry - I didn't use QGIS but GRASS to visualize the resulting map. QGIS
visualizes those data differently. In GRASS the closed lines are displayed as
an area but only exist as a boundary without any information.
Some time ago there was a discussion about when to display a closed line as an
area and when not. I still do not know (don't remember), why in GRASS those
closed boundaries, in my opinion no areas, are displayed.
Can someone help out again and explain? I think there was a good reason for
this - right?
  thanks
   Otto
Best regards,
Wolfgang
> Wanted: howto!
> > Hi Otto, hi list.
> Hi,
> Otto
> > 1_polygon) - works.
> d.vect,
> > Wolfgang
> > > Wanted: howto!
> > > > Hi List,
> > > Hi,
> it
> > > would
> > > > type=boundary
> > > today and got
> ring.
> > > Otto
> create
> > > a
> boundary
> > > theme
> > > > the
> > > shape
> > > > inside)
> > > > Best wishes,
> > > > Wolfgang
On Wed, Dec 21, 2005 at 11:22:33AM +0100, we recorded a bogon-computron collision of the <Wolfgang.Qual@gmx.net> flavor, containing:
Hi List,
I'm not exactly sure why this is, but apparently d.vect displays these areas
by showing both categorized polygons (the ones you intended) and
uncategorized polygons (the ones that fill all the spaces in between). If you
try
  d.vect map=buff_ausschnitt where="cat<>0"
I think you'll get only the areas you really wanted.
Tom Russo KM5VY SAR502 DM64ux http://www.swcp.com/~russo/
Tijeras, NM QRPL#1592 K2#398 SOC#236 AHTB#1
"The only thing you can do easily is be wrong, and that's hardly
  worth the effort." -- Norton Juster
