[GRASSLIST:9596] Problem with 2 vectors area layer.
Hi guys!
Got a problem with merging 2 vector area layer. The first one has got a
table associated wich is something like this:
REGION NAME AREA
name1 1212121
name2 121323321
The second area vector layer, describes areas inside each region.The tab
associated is:
CAT NAME
1 test1
2 test2
I need a vector layer like the second one, but with a tab wich has got a
column with the name of the reagion in wich each area is.
CAT NAME REGION
1 test1 name1
2 test2 name2
3 test3 name3
Thx
P.S. all the tables are inside Postgress.
Luca
"Esperienza รจ il nome che ciascuno da ai suoi errori. (O. Wilde) "
GENTOO-GIS Development Team
jabber: casagrande@jabber.linux.it
v.overlay operator=and
then you can change columns name and also remove columns...
hope this help...
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini@unipg.it
        ivan.marchesini@gmail.com
tel: +39(0)755853760
fax: +39(0)755853756
