OK, I just tried it again, this time running grass61 -gui and so avoiding the WISH and gui problems.
I tried a bit more fussing with the setup. ODBC is a mystery to me, and I'm probably messing it up. I tried installing the driver first in my own Library/ODBC directory, then in the system wide /Library/ODBC, and experimented with both system DSN and user DSN's. The user DSN didn't work:
db.test test=test1
create table grass_test1 (i1 integer, d1 double precision, c1 varchar(20))
DBMI-ODBC driver error: SQLConnect():
[iODBC][Driver Manager]Data source name not found and no default driver specified. Driver could not be loaded (0)
... etc. etc....
Setting up ODBC as a system DSN gave different errors:
db.test test=test1
[DataDirect][ODBC SequeLink driver][SequeLink Client]TCP/IP error, connection refused (2306)
EXECUTE: ******** ERROR ********
insert into grass_test1 values ( 1, 123.456, 'abcd' )
So at least it seems to be locating the driver, but the driver isn't connecting to the database? Here the instructions that come with FMP7 aren't that helpful to me; I'm sure they'd be enough for someone who knows ODBC. I used the ODBC Administrator that comes with Mac OSX 10.4.3, set up a System DSN with values Host=localhost, Port=2399, ServerDataSource = database name, in this case just ODBCTest. Filemaker is set up to share the database via ODBC, and is running.
Ideas?
Nick Cahill
On Dec 22, 2005, at 5:34 PM, William Kyngesburye wrote:
(I bumping this back to the list, Nick)
On Dec 22, 2005, at 1:28 AM, Nick Cahill wrote:
Dear William,
Sorry, it's been a very hectic couple weeks and I had to put off testing GRASS and Filemaker.
I hear you.
I just made a stab at it - installing the ODBC driver and such. I have FMP 7 and the driver, and hope they're configured correctly. However, when I run your GRASS, I get an error:
channel "console1" wasn't opened for writing
while executing
"error $fh"
(procedure "run_cmd" line 24)
invoked from within
"run_cmd 2"
invoked from within
".dialog1.run invoke"
("uplevel" body line 1)
invoked from within
"uplevel #0 [list $w invoke]"
(procedure "tk::ButtonUp" line 23)
invoked from within
"tk::ButtonUp .dialog1.run"
(command bound to event)
so I can't run any GUI commands.
Is that right when you run grass in GUI mode? ie grass61 -gui. Oh, your tcl/wish settings might be looking at a different Tcl/Tk. Try setting this in your .bash_profile:
export GRASS_TCLSH=/usr/local/grasslibsx/bin/tclsh8.4
export GRASS_WISH=/usr/local/grasslibsx/bin/wish8.4
(or use setenv in .cshrc for the tcsh)
So I tried it from the command line. I had set up a FMPro database called ODBCTest, shared it from within FM, but I don't have the ODBC Admin program that lets me test whether the connection is actually set up - so there may be a problem there. .In any case I got:
GRASS 6.1.cvs (sardis):/usr/local/bin > db.connect driver=odbc database=ODBCTest
GRASS 6.1.cvs (sardis):/usr/local/bin > db.test test=test1
I think this is where the DSN comes in. As it says, iODBC doesn't have a DSN defined for the database you specified. The DSN ties a specific database name (what you use in db.connect) to an ODBC driver and source database. The GRASS docs for the db commands don't say much on this (maybe somewhere there is more info), but the GDAL docs on ODBC connections helped me to understand this. How you setup the DSN (parameters and such) is still hazy, all I know is you use ODBC Administrator.
Someone on the list might know more about ODBC. I hope we can get this working
William Kyngesburye <kyngchaos@kyngchaos.com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
