[GRASSLIST:963] Newbie Problem with Raster File Import GRASS 5
I'm sure that this is a pure ignorance issue but I don't see anything
obvious in the docs so a gentle pointer to the appropriate TFM or a direct
to the point answer sure would be appreciated.
I set up a location with what I think are appropriate parameters.
g.region gives me this:
CURRENT REGION: N=41:37:48.36N S=41:32:48.48N RES=0:00:00.36 ROWS=833
                E=74:53:43.44W W=75:02:35.52W RES=0:00:00.36 COLS=1478
PROJECTION: 3 (Latitude-Longitude)
ZONE: 0
DATUM: ** unknown (default WGS84) **
ELLIPSOID: wgs84
I have a tiff image from topozone with an associated tfw file that shows
this:
5.0800000000
0.0000000000
0.0000000000
-5.0800000000
495812.6492529264
4609362.2176114470
When I attempt to import the file I get this:
TIFF Directory at offset 0x8
  Subfile Type: multi-page document (2 = 0x2)
  Image Width: 2657 Image Length: 2165
  Resolution: 150, 150 pixels/inch
  Bits/Sample: 8
  Compression Scheme: None
  Photometric Interpretation: RGB color
  Orientation: row 0 top, col 0 lhs
  Samples/Pixel: 3
  Rows/Strip: 1
  Planar Configuration: single image plane
  Page Number: 0-1
  Looking for TIFF World file ... Found it!
WARNING: G_set_window(): Illegal latitude for North
ERROR: couldn't set cellhd.
I suspect that the region's latitude doesn't accommodate the tfw file's
parameters but I'll be darned (or worse) if I can figure how the region
needs to be changed.
The raster file is really the set of boundries that I wanted, how do I
convert the tfw file's easting/northing information to lat/lon (if that is
the appropriate way to fix the issue?
Any help would be appreciated.
Dave
Hi
ROWS=833
                COLS=1478
ZONE: 0
ELLIPSOID: wgs84
shows this:
5.0800000000
0.0000000000
0.0000000000
-5.0800000000
495812.6492529264
4609362.2176114470
Do you know the projection of this tfw file? You will need it if you
want to transfor it into your lat/lon location.
you find some general information on
http://grass.itc.it/gdp/grass5tutor/HTML_en/c1418.html
see the man page (man r.proj) for detailed information, how to
convert a raster file into another projection.
file's parameters but I'll be darned (or worse) if I can figure
how the region needs to be changed.
If you dont have any projection information for the raster file.
just set up an x,y location in grass an import the raster file
unprojected. set the region extend to the raster file's boundaries,
you have mentioned above.
do I convert the tfw file's easting/northing information to
lat/lon (if that is the appropriate way to fix the issue?
see man r.proj (This assumes that you have compiled with proj4
support.
Hoped that helped
Johannes
-- Johannes Buehler
   __O Feldstr. 45
=`\<, 14789 Greifswald
(=)/(=) johannesbuehler@oderbruecke.de
----------- 03834 509307
ZONE: 0
ELLIPSOID: wgs84
this:
5.0800000000
0.0000000000
0.0000000000
-5.0800000000
495812.6492529264
4609362.2176114470
The last two numbers indicate that this *isn't* lat/lon, so don't try
to import it into a lat/lon location. Ideally, import it into a
location whose projection matches that of the image. If you don't know
the image's projection, import it into an X/Y location instead.
If you import it into a location with a known projection (i.e. not
X/Y), you can then re-project it into a lat/lon location with r.proj.
  Bits/Sample: 8
  Samples/Pixel: 3
  Rows/Strip: 1
  Page Number: 0-1
The region isn't used when importing images; instead, they are
imported cell-for-cell, with default boundaries.
The map's boundaries will initially be set using the georeferencing
information from the image, (if such is present, and if the import
utility understands it).
If the image isn't georeferenced (or if the importer doesn't support
it), the initial boundaries will have the bottom-left corner at the
origin of the location's coordinate system (i.e. <0,0>), and will be
sized such that one unit (foot, metre, degree) equals one cell
(pixel).
This can cause problems for importing into a lat/lon location. If the
image is more than 90 pixels high, you will get an "Illegal latitude"
error as above (similarly for images more than 180 pixels wide). A
possible workaround is to change the location's projection to X/Y
before importing, then set it back afterwards (IIRC, r.in.tiff does
this automatically).
In any case, you can subsequently change the image's boundaries using
r.region or r.support.
It almost certainly isn't correct. For most projections (i.e.
everything except Plate Carée, aka Equidistant Cylindrical), the
relationship between lat/lon and projected coordinates is non-linear.
