Karl,
[ after having received offlist the data]
ok.
the problem is that GRASS by default applies
a linear color table. However, with the megacities
in Asia and elsewhere, this doesn't quite work
the solution is to apply a custom color table,
or, as a first approach, a logarithmic table
r.colors asds00gialpha1 col=grey.log
d.rast asds00gialpha1
Works
On Wed, Dec 28, 2005 at 03:42:42PM +0100, Karl Broich wrote:
Markus,
At 11:23 28.12.2005 +0100, you wrote:
>Karl,
>did you zoom to the map?
no.
>g.region rast=gpw -p
>Then you may check the statistics (probably just the color
>table is non-representative):
>r.univar gpw
total null and non-null cells: 5246208
total null cells: 0
Of the non-null cells:
n: 5246208
minimum: 0
maximum: 5.85072e-39
range: 5.85072e-39
mean: 5.68089e-44
standard deviation: 2.93343e-42
variance: 8.60502e-84
variation coefficient: 5163.69 %
sum: 2.98031e-37
>If everything is still zero, please let us know.
It is not exactly zero but very, very small.
Is there something wrong with this data? How can I check this?
Just for Information: I used GRASS 6.1 CVS.
Karl
Dr.-Ing. Karl BROICH Tel: +49 / (0) 89 / 6004 2478
Universität der Bundeswehr München Fax: +49 / (0) 89 / 6004 3858
Institut für Wasserwesen
Werner-Heisenberg-Weg 39
D 85577 Neubiberg
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
