[GRASSLIST:965] Importing a Scanned Map?
I am new to GRASS and just getting started. I have a scanned image of a USGS topographic map that I would like to start with and have been working through the tutorial in grass50_tutorial_en.pdf. On page 79 step "d.", second bullet it says "Change to the GRASS monitor. Here display the imported map." How is this done? I have launched "d.mon x0" in step c. run i.points as stated at the beginning of step d. and I have a blank monitor screen. Now what? Anything I have been able to think of to get a map display either just doesn't work or generates a error. It seems there is a bit of "magic" here that is not explained.
      The scanned image was imported with r.in.tiff. r.in.gdal seg faults every time I run it. I have also converted the image to PNG and r.in.png blows up because it is asking specifically for libpng.so.2. The Linux installation is Mandrake 9.1 just freshly installed.
Chris Marshall
that's right. If you have another monitor open you might need
d.mon select=x0 as well..
g.region rast=scannedmap # zoom to the bounds of the imported map
d.rast scannedmap
(you should have imported into a XY location)
some of my old notes:
To register a TIFF:
eg NZ7624.tiff:
  info from GIMP/Paint Shop Pro:
    299x299 dpi
    Orig Map Scale 1:60,000
    256-colours
    8412x12601 pixels
  As per Intro to GRASS, p27:
    1cm = 600m
    299 dpi = 299/2.54cm = 117.72 lines/cm
    Per cm, the ratio is: 600m/117.72 = 5.097m/line
    Cell resolution is therefore 5.097m2.
  Mind the disk space! May be hundreds of MB a piece!
r.in.tiff Easier with support file.
(i.group) Make a new map group, add new raster to that group
i.target \
i.point \
i.rectify _\/_
see the tutorial for much better instructions:
http://grass.ibiblio.org/gdp/grass5tutor/HTML_en/c1014.html
r.in.gdal seg
hopefully someone else on the list can help you with that, as they are
things which should be fixed in GRASS.
good luck,
Hamish
