hi all... I'm trying to work through an "assignment" i have from
work. normally i use that "other" software package with extensive
knowledge and ease. I am trying to make the migration to GRASS, and
hope to help others "jump-ship" as well. GRASS is just too powerful,
flexible and has such intelligent designers and developers that its
too intriguing not to use. plus i love Linux so its an easy sell for
me. just hoping i can get a handle on doing some of the major tasks i
do in that "other" software done in GRASS. then i should be on my
way...
I did a v.buffer on some points and got the buffers. i have been
using/following the v.buffer man page.
(I think) I did the following processes correct so far: I did the
buffer on points, have non-overlapping buffers. then I did the v.type
change on my points to centroids. then I did the v.patch with the
centroids and the buffers. then i got stuck.
I tried to use this--->
v. db.connect map=seep_db table=seepage key=cat driver=dbf
database='/home/jumpship/gis/flsp83/PERMANENT/dbf/'
but got this output--->
ERROR: Use -o to overwrite existing link for layer <1>
what does this error mean?
and do I understand correctly that this process will attach the
attributes from the original GRASS point dataset (seepage) to the
buffered areas/centroids that were "patched"? this would be exactly
what I am looking to do.
