[GRASSLIST:9715] which linux distribution?
If you are already used to Debian, but want something more up-to-date,
I recommend you try Ubuntu (http://ubuntulinux.org/). It is Debian
based, and very good. Just don't forget to check on the Ubuntu wiki
what you need to install in order to be able to compile stuff.
Carlos
On 1/4/06, Robert Kuszinger <kuszinger@giscom.hu> wrote:
Hi all!
I'm planning to put a second HDD into my notebook for using grass as it
seems to be
much more up-to-date and better on Linux than under Cygwin (which is good
for many things, really, and good to have, but I better use Linux for
production)
My question is, which Linux distribution to choose?
I have Debian but that is versions back for stability (i do understand) and
if I switch to the unstable tree in sources.list it starts to create strange
links
(if I install a library, it uninstalls another and changes version and I
loose an important package,
etc)
What do you use for compiling/development, for example? Which one is the
best.
My main target application is GRASS, so this is the main point.
thanks
Robert
              Carlos Henrique Grohmann - Guano
  Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
2006/1/4, Carlos "Guâno" Grohmann <carlos.grohmann@gmail.com>:
I point you to Debian's testing version. It benefits from all the
tuning done in unstable,
and, despite it's name, is quite stable software-wise
As we head towards Etch release, we should see waves of transitions
which may make youself nervous, but those go away swiftly...
I am running testing since the begining of 2005 without any major problem.
my 2 cents worth.
Paulo Marcondes
PU2PIX/PU1
Debian GNU/Linux = http://rj.debianbrasil.org
Forgot to mention, this same discussion happened some time ago,
maybe the list archives could help you.
Paulo Marcondes
PU2PIX/PU1
LibraNet was easy to install and use, if it is a concern;
but I have noticed a distribution called "Quantian ", Grass included (an old version)
and this link is informative.
http://grass.itc.it/pipermail/grassuser/2003-June/009382.html
OtunabalikO
Yahoo! Photos
Ring in the New Year with Photo Calendars. Add photos, events, holidays, whatever.
this could be a good Q for GRASS FAQ, as it gets raised tome to time.
Answer is: any GNU/Linux will fit, if it offers compilation tools (GCC
with friends).
I run GRASS on Slackware and Gentoo. On both systems compiled from
sources (CVS snapshot), both are fine.
May bee better is to ask - how good work GRASS package developers on
different distros?
Slackware - no official GIS support at all;
Gentoo - GRASS 6.0.1 is in portage with all dependencies (x86, sparc -
stable, amd64, ppc - testing).
Maris.
2006/1/5, tunabalik <tuna_balik@yahoo.com>:
old version)
OtunabalikO
Yahoo! Photos
whatever.
On Thursday 05 January 2006 08:39, you wrote:
with friends).
different distros?
From our local mirror:
$ find mandriva/ -name 'grass*.rpm'|grep -v src
mandriva/devel/10.0/contrib/i586/grass-5.0.3-2mdk.i586.rpm
mandriva/devel/10.1/i586/media/contrib/grass-5.0.3-3mdk.i586.rpm
mandriva/devel/10.1/i586/media/contrib/grass53-5.3.0-1mdk.i586.rpm
mandriva/devel/10.1/i586/media/contrib/grass57-5.7.0-3mdk.i586.rpm
mandriva/devel/10.1/ppc/media/contrib/grass-5.0.3-2mdk.ppc.rpm
mandriva/devel/10.2/i586/media/contrib/grass-6.0.0-2mdk.i586.rpm
mandriva/devel/10.2/i586/media/contrib/grass53-5.3.0-1mdk.i586.rpm
mandriva/devel/10.2/i586/media/contrib/grass54-5.4.0-1mdk.i586.rpm
mandriva/devel/10.2/ppc/media/contrib/grass-5.0.3-2mdk.ppc.rpm
mandriva/devel/2006.0/i586/media/contrib/grass-6.0.0-3mdk.i586.rpm
mandriva/devel/2006.0/i586/media/contrib/grass54-5.4.0-1mdk.i586.rpm
mandriva/devel/cooker/i586/media/contrib/grass-6.0.1-4mdk.i586.rpm
mandriva/devel/cooker/i586/media/contrib/grass54-5.4.0-2mdk.i586.rpm
mandriva/devel/cooker/i586/media/debug_contrib/grass-debug-6.0.1-4mdk.i586.rpm
mandriva/devel/cooker/i586/media/debug_contrib/grass54-debug-5.4.0-2mdk.i586.rpm
mandriva/devel/cooker/ppc/media/contrib/grass-5.0.3-2mdk.ppc.rpm
mandriva/official/10.0/contrib/i586/grass-5.0.3-2mdk.i586.rpm
mandriva/official/10.1/i586/media/contrib/grass-5.0.3-3mdk.i586.rpm
mandriva/official/10.1/i586/media/contrib/grass53-5.3.0-1mdk.i586.rpm
mandriva/official/10.1/i586/media/contrib/grass57-5.7.0-3mdk.i586.rpm
mandriva/official/10.2/i586/media/contrib/grass-6.0.0-2mdk.i586.rpm
mandriva/official/10.2/i586/media/contrib/grass53-5.3.0-1mdk.i586.rpm
mandriva/official/10.2/i586/media/contrib/grass54-5.4.0-1mdk.i586.rpm
mandriva/official/2006.0/i586/media/contrib/grass-6.0.0-3mdk.i586.rpm
mandriva/official/2006.0/i586/media/contrib/grass54-5.4.0-1mdk.i586.rpm
mandriva/official/9.1/contrib/i586/grass-5.0.0-3mdk.i586.rpm
mandriva/official/9.1/contrib/ppc/grass-5.0.0-3mdk.ppc.rpm
mandriva/official/9.2/contrib/i586/grass-5.0.2-1mdk.i586.rpm
mandriva/old/9.0/contrib/RPMS/grass-5.0.0-1mdk.i586.rpm
mandriva/old/testing/Mandrivaclub/9.1/i586/grass-5.0.2-1.1mdk.i586.rpm
mandriva/old/testing/Mandrivaclub/9.1/i586/grass-5.0.2-1mdk.i586.rpm
2006 shipped with 6.0.0 due to problems with grass 6 under gcc4, which still
need to be solved in cooker (g.parser and nviz segfault). I may update the
packages in devel/2006.0 when this is solved.
amd64 packages will be available in future, possibly current ones for ppc as
well.
Buchan
Buchan Milne
B.Eng,RHCE(803004789010797),LPIC-2(LPI000074592)
