I want to import a *.hdf file into grass raster file format and then convert it to *.img format.
My grass version is 5.0.0 ,this does not have a r.in.hdf file loaded. When I go for downloading the r.in.hdf on the internet (in the GRASS data import help page), it does not display any such command or any module that supports .hdf format. How should I download the "r.in.hdf" code to put it in my grass version or is there any way to convert .hdf to grass raster format and then to .img format. I want some help. Thanks in advance.
uttam
_________________________________________________________________
Race along with NK. The fastest Indian. http://server1.msn.co.in/sp03/tataracing/index.asp Feel the thrill!
On Tue, Aug 19, 2003 at 04:57:21PM +0530, Uttam Kumar wrote:
Although slightly updated, the r.in.hdf is not functional.
However, r.in.gdal will import HDF files if you have installed
a GDAL library with HDF support compiled in.
Like that r.in.gdal imports ASTER, ASTER DEM, MODIS etc.
