[GRASSLIST:9742] vector corruption? after qgis session crash
After a QGIS editing session crash, the vector that i was editing now has a
small problem. when working with this vector i get the following warning:
d.vect pedons
D1/1: Info->size = 6481, Info->mtime = 1136524613
D1/1: coor size in head = 6452, real coor file size= 6481
WARNING: coor files of vector 'pedons@waypts' is larger than it should be
         (29 bytes excess).
this file seems to work, but the warning is annoying. I have tried v.build,
however this does not fix the problem. is there any quick way to fix this, or
am i going to have to export the vector to text, and re-import it ?
thanks in advance,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
Hi Dylan,
I’ve had the same problem a couple of times and running v.build solved it before. Maybe you could enter GRASS’ digitize mode and exit without modifying your vector file?
HTH,
Jaime
Dylan Beaudette dylan.beaudette@gmail.com escribió:
d.vect pedons
WARNING: coor files of vector ‘pedons@waypts’ is larger than it should be
(29 bytes excess).
however this does not fix the problem. is there any q! uick way to fix this, or
thanks in advance,
Dylan Beaudette
530.754.7341
Correo Yahoo!
Espacio para todos tus mensajes, antivirus y antispam ¡gratis!
Regístrate ya - http://correo.espanol.yahoo.com/
I have run into something like this too before. My hack around it was to use v.extract where=cat>0 to grab everything out of the damaged vector file. My resulting vector was error free.
G'luck,
Ian
On Jan 5, 2006, at 9:35 PM, Dylan Beaudette wrote:
d.vect pedons
         (29 bytes excess).
thanks in advance,
Dylan Beaudette
530.754.7341
This message has been scanned by Postini anti-virus software.
On Thursday 05 January 2006 09:35 pm, Dylan Beaudette wrote:
d.vect pedons
         (29 bytes excess).
or am i going to have to export the vector to text, and re-import it ?
thanks in advance,
Thanks for the tips. Opening the vector in v.digit, adding a new point, and
quitting seemed to fix the problem.
Yay!
Dylan Beaudette
530.754.7341
> Hi,
> d.vect pedons
> (29 bytes excess).
> thanks in advance,
Yay!
Open and close should be enough.
Radim
Dylan Beaudette
530.754.7341
