[GRASSLIST:9764] NVIZ fails to build on an up-to-date Ubuntu Hoary (was: errors building today's NVIZ)
No matter what I do, NVIZ deosn't build in any Grass 6.0 or 6.1 I try on
my Ubuntu Hoary. Can any Hoary user please check if it works for him?
The error I'm continously getting is:
maciek@sorbus:~/src/straight/grass6/visualization/nviz$ make
cd src ; make
make[1]: Entering directory
`/home/maciek/src/straight/grass6/visualization/nviz/src'
gcc -Wl,--export-dynamic -L/home/maciek/src/straight/grass6/dist./lib
-Wl,-rpath-link,/home/maciek/src/straight/grass6/dist./lib
-o /home/maciek/src/straight/grass6/dist./bin/nviz OBJ./nvizAppInit.o
OBJ./change_view.o OBJ./draw.o OBJ./exag.o OBJ./glwrappers.o
OBJ./init_commands.o OBJ./lights.o OBJ./map_obj.o OBJ./misc.o
OBJ./nviz_init.o OBJ./position.o OBJ./quick_draw.o OBJ./anim_support.o
OBJ./cutplane_obj.o OBJ./script_support.o OBJ./do_zoom.o OBJ./label.o
OBJ./nvizMain.o OBJ./togl.o OBJ./togl_cb.o OBJ./query_vect.o
OBJ./volume.o OBJ./togl_flythrough.o -lgrass_ogsf -lgrass_image \
-lgrass_bitmap -lgrass_linkm -lgrass_vect -lgrass_dig2 -lgrass_dgl
-lgrass_rtree -lgrass_linkm -lgrass_dbmiclient -lgrass_dbmibase
-L/usr/local/lib -lgdal -lgrass_sites -lgrass_form -lgrass_dbmiclient
-lgrass_dbmibase \
-lgrass_gis -lgrass_datetime -lz -lm -lz \
-lgrass_datetime -ltk8.3 -lm -ltcl8.3 -lm -lGLU -lGL -lpthread -lSM
-lICE -lX11 -lXmu -lXext -lm -ldl -lz -L/usr/X11R6/lib -ltiff \
  -lSM -lICE -lX11 -lgrass_g3d
/usr/X11R6/lib/libGL.a(glxcmds.o)(.text+0x2eea): In function
`glXGetMscRateOML':: undefined reference to `XF86VidModeQueryVersion'
/usr/X11R6/lib/libGL.a(glxcmds.o)(.text+0x2f1a): In function
`glXGetMscRateOML':: undefined reference to `XF86VidModeGetModeLine'
collect2: ld returned 1 exit status
make[1]: *** [/home/maciek/src/straight/grass6/dist./bin/nviz] Error 1
make[1]: Leaving directory
make: *** [nvwish] Error 2
The ./configure was:
--with-cxx
--without-odbc
--enable-largefile
--with-sqlite
--with-tcltk-includes="/usr/include/tcl8.3/" "/usr/include/tk8.3/"
--with-postgres-includes="/usr/include/postgresql/"
--with-freetype
--with-freetype-includes="/usr/include/freetype2/"
The last succesfull Grass 6.1 CVS build on my machine was on 2005-11-16.
However, now the 2005-11-16 CVS revision fails. Thus I assume something
that was introduced to my system since 2005-11-16 causes the problem. I
have no idea what this exactly could be though. Since then I have been
updating my machine several times, keeping it always up to date.
Eg. the kernel revision changed. On 2005-11-16 it was:
linux-image-2.6.10-5-686 (2.6.10-34.7)
Now it's:
linux-image-2.6.10-6-686 (2.6.10-34.8)
And I'm mentioning it because of what I learned form Markus Neteler:
Markus Neteler wrote:
isn't it strange that there is no architecture?
It should be
.../grass6/dist.i686-pc-linux-gnu/lib ...
What do you think of it?
I can't build NVIZ anymore which I have to use often. No good. Please
help.
Maciek
W polskim Internecie s± setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.panoramainternetu.pl/
Hi Maciek,
here is something that came up related to NVIZ and X.org last september:
http://grass.itc.it/pipermail/grass5/2005-September/019676.html
as stated in the above message, the fix was to :
add -lXxf86vm to the /nviz/src/Makefile
...and as Glynn Clements pointed out, this is a bit strange.
Hope that works!
Dylan
On Jan 8, 2006, at 1:16 PM, Maciek Sieczka wrote:
cd src ; make
-lgrass_dbmibase \
--with-cxx
--without-odbc
--enable-largefile
--with-sqlite
--with-freetype
Now it's:
It should be
help.
Maciek
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
Right. However, NVIZ isn't using these functions; libGL itself is.
The obvious question is: why is libGL a static library rather than a
shared library? A shared library would have the relevant dependency
information:
  $ ldd /usr/lib/libGL.so
    libpthread.so.0 => /lib/libpthread.so.0 (0x4007e000)
    libXxf86vm.so.1 => /usr/lib/libXxf86vm.so.1 (0x400d1000)
    libXext.so.6 => /usr/lib/libXext.so.6 (0x400d7000)
    libX11.so.6 => /usr/lib/libX11.so.6 (0x400e5000)
    libdl.so.2 => /lib/libdl.so.2 (0x401ae000)
    libc.so.6 => /lib/libc.so.6 (0x401b2000)
    /lib/ld-linux.so.2 (0x80000000)
Static libraries don't have dependency information, so the only
solution is for the configure script to try adding various other
libraries which might be required.
The libGL check in configure.in should probably be updated to:
LOC_CHECK_LIBS(GL,glBegin,OpenGL,$OPENGL_LIB_PATH,OPENGLLIB,$X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB,-lpthread,-ldl,-lXxf86vm)
For what it is worth, I just compiled GRASS CVS this weekend on Ubuntu
5.10. NVIS is working fine (against my new nVidia Graphics card even).
David
information:
David Finlayson
Marine Geology & Geophysics
School of Oceanography
Box 357940
University of Washington
Seattle, WA 98195-7940
USA
Office: Marine Sciences Building, Room 112
Phone: (206) 616-9407
Web: http://students.washington.edu/dfinlays
I confirm that. I built today's Grass 6.1 CVS on 5.10 with no problem on
another machine. I'll upgrade to Breezy on my laptop soon too, but I'm
not eager yet. Firts I'd like to get Grass to build on 5.04 as well.
Thanks to All for your remarks. So I see I need install to
libXxf86vm-dev (done) and add a "-lXxf86vm" flag to the linker. But I
don't know how-to.
Trying:
export LDFLAGS="-lXxf86vm"
at ./configure i get:
checking host system type... i686-pc-linux-gnu
checking for gcc... gcc
checking whether the C compiler (gcc -lXxf86vm) works... no
configure: error: installation or configuration problem: C compiler
cannot create executables.
How do I set this flag correctly?
Dylan suggested another way:
How do I do it, exactly?
I also tried to
export
X11_Xext_LIB="/usr/X11R6/lib/libXext.so:/usr/X11R6/lib/libXxf86vm.so" as
advised on http://vtk.org/Bug/bug.php?op=show&bugid=1777&pos=0, but this
doesn't change anything - still NVIZ fails to build.
Maciek
Szukasz do¶wiadczonej firmy poligraficznej? Zale¿y Ci na terminowo¶ci i atrakcyjnych cenach?
Zapraszamy do nas!
http://www.foldruk.pl/
don't know how-to.
This worked for me:
add
"-lXxf86vm"
cheers,
Dylan
Trying:
I also tried to
export
Maciek
atrakcyjnych cenach? Zapraszamy do nas!
Dylan Beaudette
530.754.7341
> don't know how-to.
This worked for me:
add
"-lXxf86vm"
Dylan,
Sorry for my ignorance, but where do I exactly put it in this file?
Maciek
Zapraszamy do nas!
> > > Ubuntu 5.10. NVIS is working fine (against my new nVidia Graphics
> > > card even).
> > on another machine. I'll upgrade to Breezy on my laptop soon too, but
> > I'm not eager yet. Firts I'd like to get Grass to build on 5.04 as
> > well.
> > don't know how-to.
> This worked for me:
> add
> "-lXxf86vm"
Dylan,
Maciek
Should have been a bit more clear:
I added it to the Makefile located at:
altering the following line:
OGL_LIBS = $(OPENGLULIB) $(OPENGLLIB) $(OPENGL32) $(XLIB) -lXmu -lXext
$(MATHLIB) $(DLLIB) $(XDRLIB) $(XEXTRALIBS) $(XLIBPATH) -lXxf86vm
See where I added '-lXxf86vm' at the end ?
Hope that helps,
Dylan Beaudette
530.754.7341
> > > card even).
> > well.
> > don't know how-to.
> This worked for me:
> add
> "-lXxf86vm"
Dylan,
Maciek
Opps!
forgot to mention that it was this file:
grass6/visualization/nviz/src/Makefile
Dylan Beaudette
530.754.7341
> > > > card even).
> > > well.
> > > don't know how-to.
> > This worked for me:
> > add
> > "-lXxf86vm"
> Dylan,
> Maciek
Cheers! This was clear enough :). Thanks a tone! NVIZ builds now on
Hoary.
Maciek
Zapraszamy do nas!
> > This worked for me:
> > add
> > "-lXxf86vm"
> Dylan,
That setting is quite badly wrong. It should probably be:
OGL_LIBS = $(XLIBPATH) $(OPENGLULIB) $(OPENGLLIB) $(OPENGL32) -lXmu
-lXxf86vm -lXext $(XLIB) $(XEXTRALIBS) $(DLLIB) $(XDRLIB) $(MATHLIB)
(all on one line).
If you're using static libraries, the order in which libraries appear
in the link command is signficant. Dependencies must come after the
libraries which depend upon them; e.g. Xlib must come after all other
X libraries, libXext must come after libXxf86vm, etc.
On Jan 10, 2006, at 7:52 PM, Glynn Clements wrote:
This worked for me:
add
"-lXxf86vm"
Dylan,
(all on one line).
Thanks for the clarification. It is now apparent that I know enough about these things to get me into serious trouble!
Cheers!
Dylan Beaudette
530.754.7341
