Do you know why specifically it may not be the best way to export
vectors (or rasters) this way? Assuming the target location the tarred
vectors are going to has the same projection and datum, can't it be
dragged and dropped?My concern is that there may be some other, necessary, information outside
the 'vector' directory. In 'dbf', for example.
An export-procedure should take care of those as well, while just tarring
the content of 'vector' does not.
-flo.
Then how about (in PERMANENT):
for map in `g.mlist type=vect pattern='vectorname'`; do tar cvf `basename
$map.tar` ./*/$map* ; done
Would that be sufficient?
~ Eric.
