I am using Grass6.0
This is the colortable command:
#______________________Raster Map
raster masked_mx
colortable y
where 0.5 0.5
height 2
fontsize 10
end
Here is the r.info results:
r.info map=masked_mx
| Layer: masked_mx Date: Fri Jan 6 16:35:21 2006 |
| Mapset: 1000N Login of Creator: mike |
| DataBase: /home/mike/projects/Chignik_Weasel |
| Title: ( test_mx4 ) |
| Type of Map: raster Number of Categories: 255 |
| Data Type: FCELL |
| Rows: 380 |
| Columns: 900 |
| Total Cells: 342000 |
| Projection: UTM (zone 0) |
| N: 250 S: -130 Res: 1 |
| E: 1800 W: 900 Res: 1 |
| Range of data: min = 29.565027 max = 103.208115 |
| Data Source: |
| vector file test_s1 |
| Data Description: |
| generated by v.surf.rst |
| Comments: |
| tension=100.000000, smoothing=1.500000 |
| dnorm=863.770803, dmin=0.500000, zmult=1.000000 |
| segmax=40, npmin=44, rmsdevi=17.001548 |
| zmin_data=23.290000, zmax_data=117.610000 |
| zmin_int=29.565027, zmax_int=103.208114 |
| k |
what is your ps.map input file syntax
what does r.info say about your raster
which Grass version?
Maciek
On wto, 2006-01-10 at 16:01 -0800, michaelp@sjgeophysics.com wrote:
> Hi Everyone,
> I am trying to add a colorbar with a color gradient to my ps.map
> instructions. My raster file is of type floating-point, and when I use
> the d.legend command I get a nice, smooth colorbar. How do I create the
> same type of colorbar in ps.map? If I try to use the colortable command
> in my ps.map script, all I get is:
> GRASS_INFO_WARNING(8431,1): Your cats/ file is invalid. A cats/ file with
> categories and labels is required for 'colortable' when using CELL
> rasters. No colortable will be assigned to this output postscript file.
> My cats file for this raster is as follows:
> # 255 categories
> 0.00 0.00 0.00 0.00
> Any help appreciated.
> Thanks, Mike.
Szukasz do¶wiadczonej firmy poligraficznej? Zale¿y Ci na terminowo¶ci i atrakcyjnych
cenach?
Zapraszamy do nas!
http://www.foldruk.pl/
