[GRASSLIST:9803] workaround for missing alter table drop column command
Hi list,
in earlier messages [1], it became clear that dbf (and sqlite) do not
support the alter table drop column command. MS wrote in this context
"... i
guess i'd have to (from reading the archives) create a temp table and
copy over only the colums I want and then re-attach it? that might be
a handy function."
But how can I do that (How can I copy over only the *columns* I want)? After
doing this: is it correct to use alter table rename to assign that temp
table the name of the source table (using sqlite; after renaming that one to
source_table_old for example)?
Using dbf-driver, would it be possible to use another programme (like
openoffice) to remove columns or would this produce corrupt data? I remeber
that this was a problem for ArcView but I thought it was possible for
GRASS..
Wolfgang
[1] http://grass.itc.it/pipermail/grassuser/2006-January/031909.html
Lust, ein paar Euro nebenbei zu verdienen? Ohne Kosten, ohne Risiko!
Satte Provisionen für GMX Partner: http://www.gmx.net/de/go/partner
