[GRASSLIST:9813] ps.map multiple rasters??
Hi to all,
I wonder if there is a way of inserting more than one raster into a map made with ps.map. This is possible with vectors, is it possible with rasters?? how??
cheers and thanks to all
Francesco
g.manual ps.map:
For each ps.map run, only one raster map layer (or set of layers or imagery group; see below) can be requested.
r.patch could help
jachym
On Fri, Jan 13, 2006 at 01:13:13PM +0100, Francesco Mirabella wrote:
Hi to all,
Francesco
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/
OFFICE:
Department of Geoinformation Technologies
LDF MZLU v Brnì
Zemìdìlská 3
613 00 Brno
e-mail: xcepicky@node.mendelu.cz
URL: http://mapserver.mendelu.cz
Tel.: +420 545 134 514
g.manual ps.map:
imagery group; see below) can be requested. ...
r.patch could help
also you could make a ps.map Encapsulated PostScript output map, then
place the EPS file(s) within another ps.map container map. Possibly
even a (mostly) blank one if say you want 4 maps arranged as so:
| Map captions.. |
In the past I have use this to put a sub-set map in a corner showing
map of the country with a region box around the area of detail in the
main map. Worked ok but the resulting Postscript file was huge.
Hamish
Hi Hamish,
thanks for your replay, I will try. In fact r.patch works fine if the
maps are of the same type, otherwise the reconstruction of the color map
can make bad results..
cheers
Francesco
> g.manual ps.map:
> r.patch could help
| Map captions.. |
Hamish
r.patch could help
map can make bad results..
the eps within another ps.map is useful if the regions will be different
(e.g. overview map + detail map at different places on the page).
If you are interested in just overlaying maps in both the same region &
place on the page, it is best to just use r.patch for maps of the same
color maps, or as Glynn explained to me on the mailing lists a few
months ago, use r.mapcalc to create red,green,blue maps using the "#"
operator combined with if() statements to provide the order (see the
r.mapcalc help page). My less efficient method was to export a PNG dump
of the display monitor, then reload that image into GRASS as a new
raster.
Hamish
Ok Hamish,
thanks for your suggestion, I will try to see what I can manage to do
with r.mapcalc
cheers
Francesco
>>> r.patch could help
raster.
Hamish
