[GRASSLIST:9824] Learning to use freetype fonts
I recently compiled GRASS with freetype support and I am trying to
learn to use it. When I follow the following sequence to define a
default font, it fails:
GRASS 6.1.cvs (WASPN_NAD83):~ > locate bitstream | grep 'Vera'
/usr/share/fonts/truetype/ttf-bitstream-vera/VeraMoBI.ttf
/usr/share/fonts/truetype/ttf-bitstream-vera/Vera.ttf
/usr/share/fonts/truetype/ttf-bitstream-vera/VeraBI.ttf
/usr/share/fonts/truetype/ttf-bitstream-vera/VeraBd.ttf
/usr/share/fonts/truetype/ttf-bitstream-vera/VeraIt.ttf
/usr/share/fonts/truetype/ttf-bitstream-vera/VeraMoBd.ttf
/usr/share/fonts/truetype/ttf-bitstream-vera/VeraMoIt.ttf
/usr/share/fonts/truetype/ttf-bitstream-vera/VeraMono.ttf
/usr/share/fonts/truetype/ttf-bitstream-vera/VeraSe.ttf
/usr/share/fonts/truetype/ttf-bitstream-vera/VeraSeBd.ttf
GRASS 6.1.cvs (WASPN_NAD83):~ > d.font.freetype
font=/usr/share/fonts/truetype/ttf-bitstream-vera/Vera.ttf
GRASS 6.1.cvs (WASPN_NAD83):~ > d.text.freetype -n text="Hello"
east=20,20 ERROR: No font selected
But, if I call the font directly in the command it works:
east=20,20 path=/usr/share/fonts/truetype/ttf-bitstream-vera/Vera.ttf
(successfully draws on the monitor)
Without d.text.freetype working, I can't see text in legends or map
titles. What's the secret to getting this working?
David
David Finlayson
Marine Geology & Geophysics
School of Oceanography
Box 357940
University of Washington
Seattle, WA 98195-7940
USA
Office: Marine Sciences Building, Room 112
Phone: (206) 616-9407
Web: http://students.washington.edu/dfinlays
That is, without d.font.freetype, I can't get legend text, etc...
David
David Finlayson
Box 357940
USA
David Finlayson
Box 357940
USA
> GRASS 6.1.cvs (WASPN_NAD83):~ > d.font.freetype \
> GRASS 6.1.cvs (WASPN_NAD83):~ > d.text.freetype -n text="Hello" \
> east=20,20
Some history:
First there were GRASS fonts* which you selected with d.font. These
fonts were used by d.text, d.legend, d.vect, d.labels, d.barscale,
d.graph, etc.
[*] cyrilc,gothgbt,gothgrt,gothitt,greekc,greekcs,greekp,
    greeks,italicc,italiccs,italict,romanc,romancs,romand,
    romans,romant,scriptc,scripts
Maybe if you were Greek you could make use of these for some text, but
for non-english it wasn't very good. And for english results could be
ugly. Many people used a graphics program to add text to exported
maps instead of using the build in fonts.
So Huidae Cho wrote d.text.freetype to draw text to the screen using
a local FreeType (or TrueType) font. This was great for everyone, but
wasn't a general & automatic solution for the above modules.
Time passed & the i18n of GRASS came to be. The FOSS4G team (AFAIK)
created the infrastructure and the d.font.freetype module so the main
GRASS font (romans et al) could be over-ridden by d.font.freetype and
so d.vect, d.legend, etc could now use FreeType fonts as the default.
Thus the d.text.freetype module is independent of the d.font.freetype
module, but the d.text module does observe the d.font.freetype setting.
In hind-sight this is pretty confusing, & I apologise if the help pages
do not make this clear. Please point out where improvements could be made.
Perhaps d.text.freetype could "pick" the font set by d.font.freetype
from the GRASS display driver if the font isn't explicitly given, instead
of an error somehow. Not sure how to extract that from the driver, maybe
d.font.freetype needs to set/update a new g.gisenv variable?
ps.map is another (confusing) story....
this doesn't work?
G> d.font.freetype font="" # turns off freetype support
G> d.font font=romans
G> echo "`g.version`" | d.text
Also, I have this in my ~/.grass.bashrc file:
alias d.font.vera='d.font.freetype /usr/share/fonts/truetype/ttf-bitstream-vera/Vera.ttf'
which I find useful.
Hamish
this doesn't work?
Yes the old vector fonts work. However, my problem is the opposite. I
can't get any FreeType text to show up using:
d.font.freetype font=/usr/share/fonts/truetype/ttf-bitstream-vera/Vera.ttf
d.legend <raster>
I see the color patches, but no text.
Likewise:
produces nothing on the screen.
However, d.text.freetype works as advertised and I see a freetype font
on the monitor. Thanks to your explanation, I now know that this is
using different code.
Is it enough to add the following during ./configure to get freetype
support for normal text operations?
--with-freetype \
--with-freetype-includes=/usr/include/freetype2 \
> > east=20,20
Some history:
d.graph, etc.
this doesn't work?
Hamish
David Finlayson
Box 357940
USA
