[GRASSLIST:9827] e00 import error?
user error maybe? this should be a standard polygon e00. i get this error on import. Is avcimport a seperate module installation or something?
v.in.e00 file=/home/johndoe/gis/maryland/PONET.E00 type=area vect=counties -v
which: no avcimport in (/usr/local/grass-6.0.1/bin:/usr/local/grass-6.0.1/scripts:/usr/local/grass-6.0.1/etc/dm/script:/usr/kerberos/bin:/usr/local/bin:/usr/bin:/bin:/usr/X11R6/bin:/home/mark/bin:)
v.in.e00: ‘avcimport’ program not found, install it first
http://avce00.maptools.org
On Sat, 14 Jan 2006, M S wrote:
you need to install the missing AVCE00 and E00Compr libraries first http://avce00.maptools.org
regards,
   Otto
-v
v.in.e00: 'avcimport' program not found, install it first
Hi All,
I m working GRASS GIS 6.2.2RC1 version on Fedora 5.
While importing vector maps i am getting error like avcimport program not
found'.
I tried ti install avcimport library but makefile extension is .vc.
How to install this library on Linux.
Pls help in this regard,
Thanking you in Advance..
With Regards,
Ms. Ashwini
regards,
   Otto
error
vect=counties
-v
View this message in context: http://www.nabble.com/-GRASSLIST%3A9827--e00-import-error--tf3116211.html#a13013370
