Yes, it's a SSURGO dataset. The version number is FGDC-STD-001-1998.
Here are the rules I used:
# WVALandforms
cat 1
where MUSYM = '5010' OR MUSYM = '5030' OR MUSYM = '5040' OR MUSYM = '5060'
OR MUSYM = 'SL'
cat 2
where MUSYM = '27B'
cat 3
where MUSYM = '107' OR MUSYM = '153' OR MUSYM = '221' OR MUSYM = '221B' OR
MUSYM = '274'OR MUSYM = '329' OR MUSYM = '354' OR MUSYM = '507' OR MUSYM =
'6' OR MUSYM = '621' OR MUSYM = '836B' OR MUSYM = '836C2' OR MUSYM = '855'
OR MUSYM = '95' OR MUSYM = '956' OR MUSYM = 'W'
cat 4
where MUSYM = '135' OR MUSYM = '173' OR MUSYM = '177' OR MUSYM = '177B' OR
MUSYM = '177C' OR MUSYM = '177C2' OR MUSYM = '178' OR MUSYM = '178B' OR
MUSYM = '1936' OR MUSYM = '457' OR MUSYM = '536' OR MUSYM = '695' OR MUSYM =
'733' OR MUSYM = '777' OR MUSYM = '777B' OR MUSYM = '777C2' OR MUSYM = '936'
OR MUSYM = '976'
cat 6
where MUSYM = '138D2' OR MUSYM = '171' OR MUSYM = '171C2' OR MUSYM = '171D2'
OR MUSYM = '171F' OR MUSYM = '198B' OR MUSYM = '213' OR MUSYM = '214' OR
MUSYM = '29' OR MUSYM = '325' OR MUSYM = '377' OR MUSYM = '398' OR MUSYM =
'407B' OR MUSYM = '412E' OR MUSYM = '444' OR MUSYM = '55' OR MUSYM = '551'
OR MUSYM = '612E2' OR MUSYM = '613' OR MUSYM = '613C' OR MUSYM = '755' OR
MUSYM = '782C2' OR MUSYM = '83C2'
cat 7
where MUSYM = '151' OR MUSYM = '152' OR MUSYM = '174' OR MUSYM = '174B' OR
MUSYM = '175' OR MUSYM = '175B' OR MUSYM = '188' OR MUSYM = '201B' OR MUSYM
= '225' OR MUSYM = '226' OR MUSYM = '236C' OR MUSYM = '236C2' OR MUSYM =
'236D2' OR MUSYM = '236E2' OR MUSYM = '236F' OR MUSYM = '284' OR MUSYM =
'284B' OR MUSYM = '284C' OR MUSYM = '335' OR MUSYM = '391B' OR MUSYM = '41B'
OR MUSYM = '41C' OR MUSYM = '558' OR MUSYM = '559' OR MUSYM = '583' OR MUSYM
= '611' OR MUSYM = '612G2' OR MUSYM = '651' OR MUSYM = '695' OR MUSYM =
'725' OR MUSYM = '73C' OR MUSYM = '73E' OR MUSYM = '84'
cat 8
where MUSYM = '138' OR MUSYM = '138B' OR MUSYM = '138C' OR MUSYM = '138C2'
OR MUSYM = '169B' OR MUSYM = '171B' OR MUSYM = '184' OR MUSYM = '213B' OR
MUSYM = '214B' OR MUSYM = '214C' OR MUSYM = '216B' OR MUSYM = '217' OR MUSYM
= '217B' OR MUSYM = '236B' OR MUSYM = '377B' OR MUSYM = '382' OR MUSYM =
'399' OR MUSYM = '412C' OR MUSYM = '471' OR MUSYM = '612B' OR MUSYM =
'612C2' OR MUSYM = '613B' OR MUSYM = '614B' OR MUSYM = '614C3' OR MUSYM =
'62C3' OR MUSYM = '62C3' OR MUSYM = '62D3' OR MUSYM = '62E3' OR MUSYM =
'638C2' OR MUSYM = '638D2' OR MUSYM = '706' OR MUSYM = '706B' OR MUSYM =
'782' OR MUSYM = '782B' OR MUSYM = '83' OR MUSYM = '83B'
Would an alternative be to add a column with the new categories to the .dbf
file, and then use this to create a new vector map? In this case, there
would be fewer categories to reclassify.
Thanks!
Nurit
On 1/14/06 8:01 PM, "Dylan Beaudette" <dylan.beaudette@gmail.com> wrote:
Looks like you are working with the NRCS-NCSS SSURGO dataset ? It would
help if you can post the SSURGO version number for this dataset, and
the rules used in v.reclass.
A quick tip for NRCS-NCSS soils data: a relational DB like MySQL/PgSQL
will save you a lot of time and effort.
I have posted some ideas on getting SSURGO v.2 data into a MySQL DB,
along with a template database here:
(see bottom of the page)
http://casoilresource.lawr.ucdavis.edu/drupal/node/99
cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
