[GRASSLIST:985] redhat8 compiling problems
Hello,
I have finally gotten to the point of compiling--with
some success due to hamish_nospam. I am able to
compile without the FLAGS but when I
#gcc test.c
I get a compile error of "no gis.h file"..any
suggestions? I have checked the read permissions
everything is find.
I then tried to recompile with hamish_nospam's
suggestion of:
CFLAGS="-03 -march=i686 -wall" LDFLAGS="-s"
./configure
CFLAGS="-03 -march=athlon -wall" LDFLAGS="-s"
./configure
--with-postgres-includes=/usr/include/pgsql/server/
--with-motif
--with-motif-includes=/usr/X11R6/LessTif/Motif1.2/include/
--with-motif-libs=/usr/X11R6/LessTif/Motif1.2/lib
--with-blas
--with-lapack
--with-glw
--with-dbm
--with-dbm-includes=/usr/include/gdbm
--with-freetype
--with-freetype-includes=/usr/include/freetype2
--with-readline
but, I get these errors:
configure: warning: CFLAGS=-03 -march=athlon -wall:
invalid host type
configure: warning: LDFLAGS=-s: invalid host type
configure: error: can only configure for one host and
one target at a time
any help?
Thanks
stef
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
#gcc test.c
everything is find.
suggestion of:
./configure
./configure
--with-motif
--with-blas
--with-lapack
--with-glw
--with-dbm
--with-freetype
--with-readline
invalid host type
1. Remove the first two lines from the above command.
2. "-wall" should be "-Wall" (upper-case "W").
