Dear list,
currently, I am working with GRASS 6.1 CVS. In my office, more people will
use GRASS and QGIS as the standard GIS. Therefore the question, which
database system to store attribute data should be used is of increasing
importance. As most of my colleagues are used to work with ArcView and it's
simple way to work with attribute data.
I played around with sqlite and grass and really like the sqlitebrowser for
viewing the tabular data and to make some modifications (add / delete
field), but I do not have any experiences on postgres and GRASS. As far as I
know, there exists no comparable tool for pg as sqlitebrowser for sqlite.
Now, I ask myself: What are the pro's and con's for postgres,sqlite or
another database management programme. What system do other GRASS users use
(and why?)?
Greetings,
Wolfgang
Lust, ein paar Euro nebenbei zu verdienen? Ohne Kosten, ohne Risiko!
Satte Provisionen für GMX Partner: http://www.gmx.net/de/go/partner
Hello Wolfgang,
On Tue, 17 Jan 2006 12:10:55 +0100 (MET) "Wolfgang Qual"
<Wolfgang.Qual@gmx.net> wrote:
Dear list,
will use GRASS and QGIS as the standard GIS. Therefore the question,
which database system to store attribute data should be used is of
increasing importance. As most of my colleagues are used to work with
ArcView and it's simple way to work with attribute data.
sqlitebrowser for viewing the tabular data and to make some
modifications (add / delete field), but I do not have any experiences
on postgres and GRASS. As far as I know, there exists no comparable
Have you seen the tool pgadmin3[1], which is easy-to-use for any taks
working on a postgres-database. I work a lot with it.
And not to forget
the webapp phppgadmin[2], which is an admin-tool for postgres-tables as
well. The positive about that is the usage in your browser, which is
quite easy.
Perhaps you should give pgadmin3 a try.
Best
Stephan
[1] http://www.pgadmin.org/
[2] http://phppgadmin.sourceforge.net/
the pro's and con's for postgres,sqlite or another database
management programme. What system do other GRASS users use (and why?)?
Greetings,
Wolfgang
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl@gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
On 1/17/06, Wolfgang Qual <Wolfgang.Qual@gmx.net> wrote:
Dear list,
(and why?)?
I found very important to have a possibility to do SQL queries from attribute
tables of vectors in different mapsets. The only possibility AFAIK
is to use schemas in postgres (one schema per mapset).
OTOH fiddling with RDBMS/schemas can be difficult for beginners.
I usualy start with dbf (but sqlite is better if it works for you)
and as work continues I am forced to swith to a new schema
on postgres. (You can switch to a different database backend
during the work in one mapset).
Radim
Greetings,
Wolfgang
