Hi, I found out today that despite compiling 5.0.2 with tcltk 8.4, I was still running the GUI with the 8.3 wish, as I has the $GRASS_WISH=/sw/bin/wish (where the 8.3 was).
After changing the variable to /usr/bin/wish I get the following error when I try to start GUI:
GRASS 5.0.2 > Error in startup script: xwininfo: error: No such window with id 0x112e2c8.
while executing
"exec xwininfo -id [winfo id .w_g] | grep -i Corners"
invoked from within
"scan [exec xwininfo -id [winfo id .w_g] | grep -i Corners] {%*s %d%d} dx dy"
(file "/usr/local/grass5/tcltkgrass/main/gui.tcl" line 1887)
invoked from within
"source $env(TCLTKGRASSBASE)/main/gui.tcl"
(file "/usr/local/grass5/bin/tcltkgrass" line 21)
[1] Exit 1 tcltkgrass
Any ideas???
Thanks
Konstantinos Theofilis
with id 0x112e2c8.
while executing
Which platform is this on?
The platform is 10.2.6 OS X
Thanks
with id 0x112e2c8.
while executing
> > with id 0x112e2c8.
> > while executing
Make sure that you are using a Unix/X11 version of Tcl/Tk, not a Mac
(Carbon/Aqua) version.
Ultimately we should get rid of the X-isms from tcltkgrass; none of
them are essential, and they harm portability.
