[GRASSLIST:993] importing coast line data
Hi all
    I wanted to know if it is possible to import coast line data into grass....
    actually I have imported bathymetric data into grass and converted it into a DEM . now the problem is that i wanted to display the coast line in order to show the relative position of the data with respect to the coast.
  basically what is important to me is the 3D image in NVIZ tool . so how can i plot the coastline so that in the 3d image i will be able to show the coast line as well
Thanking all in advance
--Amit--
Hi Amit,
well i had imported some coastline data into GRASS
sometime ago so might be the same procedure cld be of
help to u its as follows:
1st create a vector ascii file and save it in the
dig_ascii folder of your location (for format of vec
asc chk the help file for v.import).
then run v.import with option 2 to import the vector
ascii file .
nw try and display the coasline using d.vect.
regards,
Ambili.
--- Amit Keney <amit@darya.nio.org> wrote: >
Hi all
grass....
grass and converted
display the coast
the coast.
in NVIZ tool . so
i will be able to
--Amit--
________________________________________________________________________
Yahoo! India Promos: Win TVs, Bikes, DVD players & more!
Go to http://in.promos.yahoo.com
