[GRASSLIST:994] Re: g.select.pg problem: list OK but refuse to select available database
En réponse à Glynn Clements <glynn.clements@virgin.net>:
Note that the g.select.pg program in 5.0.2 (and earlier) doesn't allow
you to "undefine" a host. Once you use "g.select.pg host=...", all
subsequent connections will be via TCP/IP. You can select a different
host, but you can't revert to Unix domain sockets.
To revert to using a Unix domain socket to connect to a local
postmaster process, you have to manually delete the PG_HOST entry from
the $GISRC file (typically ~/.grassrc5).
This is fixed in the CVS HEAD version, and should be fixed in 5.0.3.
Thanks for the tip! What had and still puzzle me is that even when the PG_HOST
is set and postmaster not accepting TCP/IP connections, the listing of the
databases succeeds but the connection not (the latter is normal, the former
may be some side effect). Since there is nothing obvious in the g.select.pg
code (both listdb and getdbname use the same functions) it may be an
artefact of the PostgreSQL API.
No. getdbname() uses the host from PG_HOST, while listdb() uses the
host from the "host=..." option.
If you use the "host=..." option, PG_HOST will be set from it before
getdbname() is called, so getdbname() and listdb() will use the same
host. However, if you don't use "host=...", getdbname() will use the
existing PG_HOST setting, while listdb() will use NULL (i.e. use a
Unix-domain socket).
The fix simply unsets PG_HOST if no "host=..." option is provided, so
not using "host=..." will revert to using a Unix-domain socket, rather
than leaving the host unchanged (the current behaviour).
